lowered 4x4
lowered 4x4
I'm new to the site and i tried finding info on lowering my truck through the search but i'm not finding anything. I am not very used to a forum page like this so i may just be doing something wrong???? Anyway anyone else on here lower their 4x4, if so what kit did you use? or what other method can be done???? most i have found are 2-4 lowering kits which if that's all i can do i'll take it, just curious from people who have already done it what they have used.
If you want it lower like a 2wd just replace the front shocks with 2wd models, that will give you a 2" drop in the front. For the rear, remove the factory lift blocks, and get a set of 2" drop shackles. That will get you about 3" in the rear. Depending on what shocks you buy you can probably get everything for under 250. Get front shocks for a 2009 thru 2013 and they will fit your truck. While your at it, you might want to consider 2wd rear shocks because they are shorter and wont bottom out as soon as the stock 4x4 ones.
Also don't listen to the clowns at vato zone, 2wd shocks will fit a 4x4
That's bad *** man, way cheaper than the kits i've seen. You sound pretty knowledgeable so any idea on new shocks???? As far a brands to go with or stay away from??? I really appreciate it.
