2010 traction control problem
Old Nov 10, 2017 | 12:24 AM
Klkratz77's Avatar
I️ have a 2010 lariat f150 and can’t get the traction control button to work. Have checked all the fuses and pulled them in hopes to reset it with no luck. Don’t have a My key set up that would not allow it to turn off so I️ know that’s not the problem. I’m left scratching my head as to why I️ can’t get the button to shut off. Is it the button itself? A wiring issue?? Would love some help with this one and curios if anyone else has had this problem have searched the forum up and down but haven’t found a similar issue. Thanks
Old Nov 10, 2017 | 10:19 AM
Plasmajab's Avatar
As in, the light is "on" on the dash and pressing the button wont shut it off, or the traction control is on but the button wont let me shut it off.
Old Nov 11, 2017 | 10:49 AM
Klkratz77's Avatar
The light is not illuminated on the dash and I can’t get the button to turn it off. Tried pressing and holding for 5 seconds and just pressing once neither work.
Old Nov 14, 2017 | 10:38 PM
jac4x4's Avatar
I had this same problem and it was fixed as a side affect when I spent much hassle trying to fix my limp home / stuck in third gear problem. Dealer replaced the harness from the transmission to the PCM and the connector at the transmission.
