Intermittent Turn Signal
Old Sep 21, 2016 | 07:29 PM
saviorllc01's Avatar
2014 F150 a year old just started intermittently blinking fast and normal on the left turn only. I changed all the lamps out and checked the LED rears. All bulbs blink but it acts like a bulb is out when its not. It blinks fast then normal, like a mind of its own. Any suggestions?
Old Sep 22, 2016 | 02:08 PM
Blown F-150's Avatar
Likely A BCM issue. I would get the dealer to look at it. The issue is if it's really intermittent, they can't reproduce and don't fix it AND they will charge you a diagnostic fee.
Old Oct 1, 2016 | 09:25 AM
Signal update!
SO WE NOW KNOW THE ISDUE IS TEMPERATURE RELATED. SIGNAL WORKS PERFECT UNTIL THE OUTSIDE TEMP REACHES 78-80 degrees. Then we start having issues. The hotter it gets the worsening gets. Have we narrowed it to A CAUSE?
Old Oct 1, 2016 | 01:42 PM
Heat adds resistance, should make the problem go away?
I'd recommend swapping back to OEM incandescent bulbs and see what happens
Old Oct 1, 2016 | 10:40 PM
ruled out. We have also noticed it will change once moving or turning ( sometimes ). I'm leaning to one of two things.....BCM or Harness? I'm just not sure how heat would cause either to act up?
Old Oct 2, 2016 | 12:18 AM
The system looks for low resistance, since you have swapped bulbs, sounds like maybe several times, I'd start by looking at the pins in the bulb holders
