Resonator delete pipe part #'s
Old Feb 16, 2016 | 12:24 AM
05RedFX4's Avatar
I've been digging around trying to find the part # for the resonator delete pipe, and I found them. Since they were a pain to find, I thought it would helpful if I created a new thread with the part #'s that would be easy to find using the search.
If your truck has the factory installed chrome exhaust tip, then the factory exhaust has a vibration damper on it, no factory tip, no damper. Dealer installed tips have no damper. Only the 145" and 157" wheelbase trucks come both ways.
9L3Z-5A212-A - 126" wb with damper
9L3Z-5A212-B - 133" wb without damper
9L3Z-5A212-F - 145" wb with damper
9L3Z-5A212-C - 145" wb without damper
9L3Z-5A212-D - 157" wb with damper
9L3Z-5A212-G - 157" wb without damper
9L3Z-5A212-E - 163" wb without damper
From what I've found, these pipes are made for the 09-10 4.6 and 5.4 trucks but fit the 2011-2014 trucks with the 5.0, 6.2, and 3.5 EB engines just fine, just get the correct wheelbase.
There was someone on another forum who had the 3.7 v-6 in a 126" truck and his factory resonator was around 30" long and he tried the delete pipe for a 126 and a 133 and they were both too short, if he would have tried a 145 pipe, he would not have had to modify the 133 pipe to fit, as the 145" pipe is 30" long and probably would have fit.
Old Feb 16, 2016 | 11:08 AM
Very good info!
One question, when you are saying Vibration Damper are you talking about the flex pipe?
One of these days i am Replacing the Resonator with a 3" pipe and deleting the Flex Pipe and going 3" there also. That way i will have a true 3" exhaust. Instead of it going 3" to 2 1/2" in the resonator then back to 3" then down to 2 1/2 inch at the flex pipe and back to 3 inch out the back.
Old Feb 16, 2016 | 12:48 PM
05RedFX4's Avatar
NO, there is a bracket on the pipe itself and a green canister mounted to the bracket.
No damper
with damper
This is where I found most of the info
http://www.f150forum.com/f38/2011-12...lution-151041/
Old Feb 20, 2016 | 02:07 PM
Good info! Bookmarked.
Old Feb 23, 2016 | 08:32 PM
Blue150's Avatar
Best part I ever took off mine. Well worth it.
Old Jun 13, 2016 | 09:35 AM
PFA's Avatar
PFA
Does this extend to the 2015/16 models as well?
Old Jun 13, 2016 | 12:19 PM
05RedFX4's Avatar
AFAIK it only applies to the 09-14's
Old Jun 15, 2016 | 10:00 AM
RSTHD150's Avatar
just found the videos, sounds a little raspy and drony....aka cheap. How many that have done this mod feel the same?
