Bad hot/ cold drivers side blender motor?
Old Dec 29, 2015 | 03:44 PM
User Error's Avatar
Anyone else had an issue with turning the climate control over to heat and the pass side blowing warm but the drivers still blowing ice cold A/C on your feet when it's cold outside? Thinking it's the driver side hot/ cold blender motor... any info on where it is? priced the part out at like 33 bucks so hoping that's all it takes to fix...
Old Jan 2, 2016 | 02:01 PM
Wookie's Avatar
I had mine changed out under warranty. Does your truck make a popping sound when changing the settings? That is a dead giveaway that the blend door is messing up.
Old Jan 3, 2016 | 02:40 PM
User Error's Avatar
No it wasn't clicking it was just dead... I swapped it... I do not advise anyone to take the quick way out on an 09 and try to do it without taking the dash out... if you have two vents running under the console there isn't enough room to pry the lower vents down to get it out without breaking stuff and destroying your hands trying to get it plugged back in...
