Help: ABS/Traction Error Codes And Diagnoses
2009 F-150 FX4 SuperCrew 4X4 5.4L
My ABS and stability control lights are on. I had the codes pulled today (listed in order):
1) C1298 (Right Rear Wheel Speed Sensor Input Signal Fault)
2) C1165 (Right Rear Wheel Speed Sensor Input Circuit Failure)
3) C1963 (Stability Control Inhibit Warning)
4) C1299 (Left Rear Wheel Speed Sensor Input Signal Fault)
5) C1175 (Left Rear Wheel Speed Sensor Input Circuit Failure)
I'll ignore the stability control code for now since I'm sure it is tied to the speed sensor errors. Anyways, I decided to inspect the rear wheels and I found this sucker just hanging beneath the right rear brake caliper:
Is this a speed sensor? Where does it plug into? Diagrams would be extremely helpful!
I am planning on ordering 2 new sensors for each rear wheel but I don't know where to begin. Any help would be appreciated!
