Both heated seats do not work 2011 Raptor
Old Dec 29, 2014 | 01:57 PM
raptorsteve's Avatar
Hello,
After many hours of researching online I'm throwing in the towel. I would love some help. I have a 2011 Raptor Super crew. The driver and passenger side heated seats do not work. The light that is on the heat controls stays on. These seats do not have ac just heat. I also have fully functioning heat system inside the truck. Every thing is pluged in and the fuses have been checked. Can you please steer me in a positive direction.
Thank you,
Steve
Old Dec 30, 2014 | 09:49 AM
FordService's Avatar
Ford Customer Service Team
Originally Posted by raptorsteve
Hello,
Thank you,
Steve
Welcome to the forum, Steve. It might be time to get your local dealership involved; I know they'd be happy to warm things up for you. How many miles are on your truck?
Crystal
Old Dec 30, 2014 | 02:10 PM
Hello Crystal,
My truck only has 27K miles on it and unfortunately I'm out of time on my warranty. I use the heated seats a dozen times per year for these Michigan winters. My next move is to take it to the dealership but, since I enjoy working on my truck I thought I would ask my fellow truck enthusiasts to help point me in a better direction. Do you have any insight for me because it looks like I'm striking out.
Thanks,
Steve
Old Dec 30, 2014 | 03:18 PM
Hello Crystal,
Thanks,
Steve
Hi Steve,
I'm not a technician, so I'm not the best resource for mechanical questions. If you decide to get your dealership involved, let me know so I can look into ways to assist.
Crystal
Old Jan 1, 2015 | 12:10 PM
WoodsTruck's Avatar
I have replaced the Drivers seat heater on my '03 Lariat and recently my '12 Lariat. I stopped by the Ford dealer and he printed me out a wiring diagram for the seat so I could find the connectors for the heat element. Once I popped those loose, it was as easy as putting a continuity tester across the leads to see if the element was burnt out. This last time it was only my lower element that was out, ordered it and pulled the seat. The factory element did not want to separate from the foam so I cleaned it up and applied the new element over the top of it, plugged in the wires and recovered the bottom and bolted in. Works fine now.
Old Jan 1, 2015 | 05:25 PM
jpetre's Avatar
Sounds weird but check your battery, I had a few weird things going on with my truck and no piles with it starting, but went ahead and checked / replaced my battery and all the electrical issues went away.
Heater would blow cold air on heat, back window wouldn't work, a few other weird things and once the battery was replaced all were working well.
Old Jan 2, 2015 | 11:21 PM
It would make sense to replace the heating element but, both sides going out at the same time? Kind of hard to believe. As for the battery, I'll check that one out. I appreciate the ideas.
Thanks,
Steve
Old Jan 2, 2015 | 11:27 PM
I can pull a diagram for you if needed as well, shoot me an email
Old Jan 6, 2015 | 09:28 AM
Hello,
Yesterday I found out that the passenger side seat does heat apparently someone has to sit in it for it to get hot. Well anyway, it works so this brings me to the most important seat,my seat (driver side). The heated seat lights by the climate control stays on when pushed. They do not go off like in other posts that I have read. So I guess I'm looking at a relay or a new element. Where are these relays at? I was also told the the relay is not a plug and play item. That the dealer have to flash or program the new seat module to the new part. Is this the case? Thank you for you help once again.
Hope you are enjoying your day,
Steve
Old Jan 7, 2015 | 12:31 PM
WoodsTruck's Avatar
If you have a multi-meter, check for resistance across the element at the plug. If no resistance, you found your problem. If you have resistance, then you might need to go further but I'm guessing the element may have burnt a "hole" in the circuit.
