Wheel spacers
Old Aug 15, 2014 | 09:25 AM
Jagtd2005's Avatar
Wheel spacers
Recently bought some 35x12.50x18 toyo open country mts and a 4 inch rough country suspension lift. They rub slightly and was trying to gather input on wheel spacers.
Old Aug 15, 2014 | 10:12 AM
gDMJoe's Avatar
The "largest" spacer that can be used is ¼" (be sure it's hub centric) because anything more will not leave enough stud threads to secure the wheel(s).
To use a ½"+ spacer ...
  1. you would need to replace all of the studs with 2"+ versions.
  2. the spacer would need to be hub centric.
The thinnest wheel adapter that you can go with is 1½" (because of the length of the studs), UNLESS the mounting flange of the rims have recesses between the lug holes to accept a portion of the stud, in which case you could use 1". Either needs to be hub centric.
