Can someone answer this right away ?
I have searched and read but can't find a concrete answer and I can't reach my dealer to confirm. I just ordered a 2014 Lariat, I am about to order some weathertec mats for my 2014 Screw Lariat and one of the questions is "Is your truck equipped with heating vents below the 1st row seats? " my 2008 had them in the centre console do the 2014's have them in the same place or under the front seats ?
I have searched and read but can't find a concrete answer and I can't reach my dealer to confirm. I am about to order some weathertec mats for my 2014 Screw Lariat and one of the questions is "Is your truck equipped with heating vents below the 1st row seats? " my 2008 had them in the centre console do the 2014's have them in the same place or under the front seats ?
look under the passenger's seat you should see a small vent
my 2014 xlt does have the vents
Just opt for yes if you're unsure, or wait. The only difference it should make is that if you say yes, the rear mat won't go quite as far under the front seats.
A lariat should NOT have floor vents, cause they're be a part of the center console. XL and XLT have floor vents; Lariat and up have console vents. I just looked at a 2013 XLT and it had floor vents. 2012 Lariat had console vents. (I work at a dealership.) Now, if you chose a front bench for your Lariat, I imagine you'd have floor vents because enough don't have a real center console then.
