XL floor mats
Any floor mat may be used -IF- you do what I did when I had my 2009 STX to eliminate any slide ...
Floor mat/liner anchor, retainers: $8
*Scrap aluminum sheet + mat retainers (part # 1W6Z-76130A83-AA)
WeatherTech with self-designed/made F-150 plaque/insert ...
- trim-off the bottom of the anchors so that they're flat.
- attach the anchors to the fabricated bracket using (say) 3M double-sided attachment tape.
- drill a hole in the end of the fabricated bracket.
- loosen the seat bolts. *Temporarily remove the outside ones.
- slide the hole-drilled-in-the-end bracket between the floor and seat mount.
- tighten the seat bolts.
