09-14 F150 Extend Cab DoorPanel Removal
Old May 31, 2014 | 12:01 AM
joshwe2002's Avatar
I wanted to change my speakers and i couldn't find a write up to show on an extend cab of the newer version so i wrote one up!
First the front door
Then i removed the small panel behind the door handle with a small pick to access the 8mm bolt
Then remove the small clip in the armrest cup to access the 8mm bolt.
Then remove the two 6mm bolt under the door panel (I think 2 maybe just 1)
Then using a flat screwdriver pry up under the door lock and window switches here first
And then here and it should pop out
Then unplug the three connectors
Two people are nice for this next step on to hold the panel and one to disconnect the power mirror plug
IMG]https://www.f150online.com/forums/members/joshwe2002-albums-2013+f150+extended+cab+panel+removal-picture199734-img-1280.jpg[/IMG]
THen from the back push on the two clips and pop the door handle through the front and the feed the handle and cable back through the hole and let dangle for now
Ta da front panel is off, Replacing the panel is just reversed of taking it off just be careful not to force it on or you will break the plastic clips.
Thats been done over and over now to the on I couldnt find!!
Pry the small plastic trim part off the top off the door
Now pry up on the window switch and unplug it.
Now pry the little piece under the pull button to access the T-50 bolt
Remove bolt and let hang
Now grab the plastic panel at the top and pull straight out at the top the bottom has tabs so pull topp back and lift straight up
This metal clip may come off on the door is so put it back on the door like so (one side stayed on one side came off with panel for me)
Now to get the two 6mm bolt on the top of the panel
No pry the small panel behing the rear door handle
THen remove the two 10 mm bolts
There are two little clips on the side of the door holding it on with one 6mm bolt behind each clip remove the clips and the bolts
Now take the 6mm bolt out underneath the panel
now remove the door handle and let it hang
Now lift up on the panel and its done!!
To put back is just the opposite of removal accept keep this in mind the panel that covers the seat belt has two tabs on the bottom that you gotta put into the door panel in the slots and then push the top into the clips
Upon placing the door panel back on the door if you remove these grommets you will do alot cussing trying to get the door lock rod in the hole!
http://cimg6.ibsrv.net/gimg/www.f150...fc12b72e4d.jpg
https://cimg5.ibsrv.net/gimg/www.f15...06fea47496.jpg
https://cimg4.ibsrv.net/gimg/www.f15...967443e3d9.jpg
