Oxygen Sensor Backordered
Old May 2, 2014 | 12:08 PM
ajsturtz's Avatar
Just had my 2012 in for a check engine light at 53k miles. Turned out to be an oxygen sensor, but they are nationally backordered, so it'll be a week or two. Must be a few others having oxygen sensor failures?
Good news is my extended warranty is covering it...
Old May 2, 2014 | 12:38 PM
mkosu04's Avatar
its probably common across many vehicles and model years... possibly even common to multiple OEMs.
So the backorder could be unrelated to any one specific F150 issue.
Old May 2, 2014 | 02:05 PM
Wookie's Avatar
^^^ this. The EB engine management system is similar to a lot of the VW/Audis that I have worked on. They all use Bosch parts. I haven't taken the time to cross reference the various sensor part numbers but I suspect many are interchangeable or only have minor differences. The back order could also be a supply chain issue or that product line might have been shut down for maintenance.
Old May 2, 2014 | 10:24 PM
The emissions warranty should cover it.
Old May 7, 2014 | 12:44 PM
FordService's Avatar
Ford Customer Service Team
ajsturtz,
Let me look and see if I can locate you a part. Send me a PM with your name, phone number, VIN, and dealer info. I'll see what I can do.
Ashley
Old May 11, 2014 | 07:24 PM
F 1Fiddy's Avatar
if its an after cat O2 sensor, then you don't need to worry about it. It has nothing to do with how the engine performs. Its just the government sniffer.
If it is before the cats, then you are probably noticing some engine issues. High fuel consumption or poor performance.
Old Jan 25, 2022 | 02:52 AM
CORYEBLEN13's Avatar
Originally Posted by fordservice
ajsturtz,
let me look and see if i can locate you a part. Send me a pm with your name, phone number, vin, and dealer info. I'll see what i can do.
Ashley
ashley, if you still work here, could you see if there is anything that can be done to help me with my steering rack replacement.
