2009 F150 Long Tube Headers
Old Apr 1, 2014 | 04:36 PM
bheeres's Avatar
I'm having trouble finding a long-tube header that says it works for a 2009, I see up to 2008 and then some for 2010 but not much listed for 09'
I was looking at Dynatech's but didn't want to buy unless I was sure the worked.
Please let me know, I will be putting a ProCharger on this truck so I need it to breath out well.
thanks.
Old Apr 1, 2014 | 08:54 PM
gDMJoe's Avatar
And the engine displacement is __________?
In the case of the 4.6L ... And the # of intake valves is __________?
And the # of drive wheels is __________?
Old Apr 1, 2014 | 08:59 PM
bheeres's Avatar
Sorry, really lacking info. 5.4L 3V 4X4
Old Apr 1, 2014 | 09:06 PM
Has to be a 5.4 cause no one makes LTs for the 4.6 except Pacesetter. Don't think 2WD or 4x4 matters either
I think the Dynatech SuperMaxx ones are supposed to fit for you, but I'm only positive about the headers for the 04-08 5.4s. Got OBX ones on my 06.
Edit: Ope, had the window open for a while and didn't see you post.
Old Apr 1, 2014 | 09:39 PM
Stainless works makes 4.6 2v headers fyi.
Anyways, Dynatech is top notch. I'd call them and stainless works to find out. SW typically is 100-200 more than Dynatech but both are excellent manufacturers. They would know about fitment. Let us know, good luck.
Old Apr 1, 2014 | 09:52 PM
Well didn't know that! Learned something for today. Ironically not in class, but not surprised by that either . . .
Old Apr 2, 2014 | 06:12 PM
Hey Man, here ya go:
Stainless Works Lt's 09-10 5.4 3V
Old Apr 2, 2014 | 07:03 PM
Mmmmm X pipe . . . lotta coin though
Old Apr 2, 2014 | 07:32 PM
Quality headers cost money. No way in hell I'd cheap out on something so tough to install. I may be in the minority on here, but that's not something I'd skimp on. Known, tried and true fit and quality.
Old Apr 2, 2014 | 07:46 PM
bheeres's Avatar
Thanks for the info, it looks like I can choose from Kook's, American Racing Headers and Stainless Works. All of which are pricy, but you typically get what you pay for.
Old Apr 6, 2014 | 10:18 PM
bheeres's Avatar
I have a SuperCrew and a rather unique build, I am interested to know how far back the end of the X - Pipe is. Or in other words will I be able to get a muffler connected so the back of the muffler is right at the back of the cab?
I will basically be running a down spout at that spot. too much rear suspension travel so the exhaust has to be done before the rear axle.
any help in figuring this out is appreciated.
Old Apr 7, 2014 | 12:47 AM
I can't tell you where that Stainless Works set up would end, but attaching a muffler to that, even if it needs to be moved back some to get it where you want it, would be an easy job. Get some 304 2.5" (or whatever size) pipe and 4 clamps and you're done.
It will definitely be short enough that it won't be ending right at the rear axle so close that you can't add a muffler. It should be at least 2 feet away from the looks of it.
Got this thing slammed or set up with long travel?
Old Apr 7, 2014 | 08:23 AM
bheeres's Avatar
Long Travel, the factory frame is cut off right at the back of the cab. 26" of rear travel.
Basically I want the back of the muffler to end at the back of the cab so only the downspout tailpipe sticks past the cab.
