TCS not working
TCS not working
The TCS on my 2009 Lariat is out of commission. The squirrely light on the dash is illuminated along with the ABS light. ABS is still functioning though. If I hold the TCS button in, the dash indicator will flash several times but stay illuminated. What's up?
But the ABS is still working. I hit the brakes on ice and the pedal pulsates and I hear the noise under the hood same as always.
SmokeRoss - But the ABS is still working. I hit the brakes on ice and the pedal pulsates and I hear the noise under the hood same as always.
Need to determine the DTC.
if ABS is working and TCS is not working - then it is likely not a wheel speed sensor.
It is more likely to be either the yaw sensor, steering sensor, or the ECU that is the problem.
ABS just compares wheel speeds, TCS requires more information to know how the vehicle is handling.
Unfortunately this is bad news, as these items are probably more expensive to fix.
like others have said - you need to have the codes checked to find the problem...
