Autospring Install with Factory 18" Wheels - Question
I'm sure this has been asked before, but I can't find the answer. On my 2010 XLT Crew 4WD, If I install the Autospring 2009-2014 FORD F-150 2.5" Complete Leveling/Lift Kit and keep my 18" stock wheels, how large of a tire can I run with absolutely no rubbing (no trimming of fenders required)? Will the 295 Terra Grapplers work?
Anyone happen to have any pics of this kit installed while keeping the factory 18" wheels?
Thanks in advance
Thanks in advance
The info is out there if you Google it.
Those tires are likely too tall and too wide to fit without at least trimming. May I ask why you don't want to trim?
I'd stick with 275/75/18 (33.1") if you want 100% assurance against rubbing.
Not sure about the 295's but the 275/70-18's fit without any leveling kit and have zero rubbing issues. I'm sure someone will answer your question. But you will likely find the info here if you search or dig thru lots of old posts, as many have wondered the same thing many times before.
Are your pics of the 325/65/18 or the 305/70/18?
Thanks again!
