snow in truck?
snow in truck?
I have a 2013 supercrew fx4 and everytime I start my truck up in the morning after a snow fall my truck inside is full of snow.My heater will only blow hot air out the passenger side and then after it thaws it will blow normal again.This morning I was making snowballs with all the snow inside my truck.I can't believe Ford would build a truck and send it to northern Canada and have this happen.This is happening to all the ford owners I know up here and the guys with the new gmc and rams are loving it.
I have taken the truck in a few times and the truck is in there again right now.Not sure what to do anymore.I have 3 months of winter left and can't handle this anymore.I thought Ford was better than this.
The snow is everywhere in my truck.My leather seats had 1/16 th inch of snow on them and as well as the rest of the front of the truck and the back seat had a light coating of snow also.The snow comes from the vents when you start it up.
Take a video of this, I wanna see it snowing inside a truck.
Me too. This sounds a little fishy and potentially trollish.
Kinda makes sense if it is really light fluffy snow there is no filter and you smell things immediately from outside (like a diesel truck)
Why can't snow float in through the system if it is -40 degrees outside everything is bitter cold.
I'm sure if you have some smoke machine outside the intake it would produce smoke on the inside coming through the vents
My wife said my truck did this when she moved it in the driveway last week... we had a ton of snow and it was "powder" type snow so it was real light.
My guess is that when the snow is that light it can get sucked in by the engine fan and then the blower also sucks it in when you first start the truck.
Its only happened once to me (well, her... I haven't seen it)
This doesn't really seem like much of a problem to me.
If it happens again, I would just put it on recirc till the truck warms up a little. Once the engine warms up even a hair the snow would melt before it gets to your vents.
The air intake is in the cowl, not under the hood.
Cover your cowl with a piece of plastic when you park it outside and brush all the snow off the hood before you remove the plastic and start it.
