Front signal DRL mod with standard Head Lamps
Old Dec 11, 2013 | 11:50 AM
Beardo052's Avatar
I have been reading post after post on switching DRL from head lamp to signal light. I have an 09 XLT with regular head lamps and want to know if i do this without ordering a relay and since my truck is Canadian i don't want to have a separate switch. I am new to reading schematics but know how to splice direct if the instructions are clear. any advice out there?
Old Dec 11, 2013 | 12:18 PM
MGDfan's Avatar
Hi & Welcome fellow Canuckistanian!
Careful now - this isn't like the previous-gen F150's - the 09+ have a integrated lighting controller ( SJB) so things need to be done with some finesse.
Consider using fogs for DRL's - more effective anyway.
In any case - a relay is going to be needed for isolation.
Best bet - wait for or PM Steve ( SSCULLY ) - he's done some research on this and won't steer you wrong. Example:
https://www.f150online.com/forums/me...d-vsn-1-0.html
Good luck!
Old Dec 12, 2013 | 12:12 PM
Beardo052's Avatar
i never considered using my fog lights, what does it take to use the fogs? i don't normally use my fogs anyways so maybe its my best route. I just hate the look of headlights always on EH'!
Old Dec 12, 2013 | 12:28 PM
MGDfan's Avatar
Hi.
Yep - fogs are a lot more noticeable than turns, unless you wanted to spend $$$ on Vled V3 switchbacks - http://www.vleds.com/v3-triton.html . Those are certainly sufficient for DRL's via the signal location.
See the link in my previous post for one method - uses a couple relays. Fogs will be on when the key is in 'run' position.
MGD, eh?
Old Dec 12, 2013 | 12:46 PM
Beardo052's Avatar
I run my truck with the light switch in the Auto position, so going this mod with the fogs will not change anything when the lights come on at night right?
Old Dec 12, 2013 | 01:30 PM
MGDfan's Avatar
I dunno what would happen on a 09+;different logic than mine perhaps, eh?
On mine, the DRL fogs go out when the heads turn on, unless I specifically select fogs.
MGD
