Super Cab Rear Door won't unlatch....
What year truck is it?
The thread linked below dealt with a '97.
https://www.f150online.com/forums/19...wont-open.html
Youtube has some very helpful videos on how to fix this.
Suicide door lower latch jammed with broken glass
How can I release the lower latch? After window glass broke, lower latch jammed closed. Handle and cables are ok.
I removed the interior panel, and every bit of glass I could see, but there may be more inside jamming the latch. I used a shop vac to get most loose glass, and sticky tape on a screwdriver to get a few bits out of tight corners. If I could get the door to open I would remove hinges, turn it upside down and shake the ***** out of it, then reassemble
Mirrored inside view of lower latch - riveted in place? 1/2" access hole visible, next step might be to expand that for better access to latch?
Glass fragments from inside door
Closest access point through this hole I drilled
Alarm did not go off after smash and grab!?! Temporary window seal. New glass ready to go in.
Thanks for ideas!
View of latch assembly before removal of visible glass fragments
Thanks for ideas!
Okay the video links I posted earlier are for 97 - 03 models.
https://search.yahoo.com/yhs/search?...h+repair+video
https://video.search.yahoo.com/yhs/search?fr=yhs-syndic8-active8&ei=UTF-8&hsimp=yhs-active8&hspart=syndic8&p=97+to+03+f150+rear+door+l atch+repair+video+youtube&type=sourceAUD1#id=18&vi d=e889b4a1bb64dfe5920d0c747da60a9e&action=view
https://www.f150online.com/forums/1997-2003-f-150/526023-back-doors-don-t-open.html
