Drivers side window switch
Old Feb 19, 2013 | 07:44 PM
drswiger's Avatar
Anyone got a step by step on how to remove the drivers side master window switch? I removed the solitary screw at the bottom of the hand grip but that didn't seem to do jack. Didn't want to break the plastic
Old Feb 20, 2013 | 03:57 AM
svt2205's Avatar
There are 4 screws that you must remove to pull your door panel. One is behind the small trim plate located in the inner door handle pocket. One is behind the small trim plate located in the door pull pocket and there are 2 located at the bottom of the door. You MUST lift the door panel off the door to remove it. Feel free to send me a PM with your email address and I can forward a pdf copy of the interior trim section of the service manual. It shows what you need to know.
Hope this helps.
Old Feb 20, 2013 | 08:32 AM
In the index of the Articles and How To section:
https://www.f150online.com/forums/ar...ow-switch.html
https://www.f150online.com/forums/ar...placement.html
https://www.f150online.com/forums/ar...supercrew.html
These are for the 2004-2008, but I bet they are much the same as on the 2010.
Old Feb 20, 2013 | 09:36 PM
drswiger's Avatar
Thank you guys tons. Got it off today with your help.
