What to add to barely low coolant?
Old Feb 18, 2013 | 04:30 PM
tyebo168's Avatar
Just finished up a oil change this past weekend. Looked over everything when putting oil in the truck. I noticed my coolant in my over flow tank is barely under the cold fill line. My questions should I even be worried about this? If I need to fill it a little, do I add just distilled water? Just concentrated gold coolant? Or a mixture of both? Thanks for the help..
Old Feb 18, 2013 | 07:23 PM
WFO's Avatar
WFO
Wouldnt even worry about it.
Old Feb 19, 2013 | 01:19 AM
If you have a 2010, you should probably consider getting it flushed and replaced. If it's barely low, water would be fine.
