What size leveling kit 2012 f150 2wd
The OP is talking about a 4x2, not a 4x4, just so any suggestions are leading him down the right path.
Ericherich02, with your truck parked on level ground, Grab a tape measure and measure from the ground to the center of the wheel arch on all 4 wheels. what is the front - rear on your 2WD truck?
I'm guessing that a 1.5 inch kit is going to be good for your truck. It's been a while since I read a thread on 2WD levels, but I seem to think the difference is less on a 2WD.
If memory serves me correctly, I think you could even add the factory 4x4 rear blocks and get it a little higher. The factory blocks are 1.25 inches, and I believe that the 2WD comes without any blocks at all. There are a number of members here who have old factory 4x4 blocks kicking around, so if you are in the block market, check out the classifieds section. https://www.f150online.com/forums/pa...2009-2013-124/
I decided to stay away from spacers when I levelled my truck. I went with a set of bilstein 5100's. Read up on them, and consider them an option before making a decision on what is right for you. http://www.bilsteinus.com/fileadmin/...WebArticle.pdf
And welcome to the forum.
and i do have a 2wd. wish i had pics up. still saving up for new tires. got my moto metals for CHEAP and sold my stocks for a few hundred, but kept stock tires for now. wider rim = shorter truck. FUGLY at the moment.
