It's that time again....
Thanks.
Dawg - I've ordered the Daystar 2" kit, and I'm going with goodyear duratrac 305/55/R20 tires. The wheels I like (Helo HE878) have a -12mm offset. Do you think I'll have clearance issues on front bumper, air dam or elsewhere? Have you run wheels with a similar offset and, if so, did they look like they extended too far outside the fender?
Thanks.
Thanks.
I ran -11mm wheels on my 2008 XLT with the 2-inch Daystar system and 305/65R18s that were 33.7 inches tall and 12.2 inches wide on the 18x9 wheels. The tires stuck out a couple of inches too but I also added 1-inch wide flares and so they didn't look like they were pushed too far out. It was a previous Gen truck but I did not do any trimming and had very little rub as well.
So I am thinking your 305/50R20s at 33.2 inches tall and 12.2 inches wide on -12mm wheels will stick out about the same, and may require some trimming at the back part of the front wheel well (where the flares tuck into the wheel well) and the lower front air dam some if you don't want any rubbing of body parts (but no issue clearing the UCAs).
I ran -12mm wheels on my 2009 FX4 with a 4-inch lift and the 18x9 wheels pushed the 35x12.5 BFG KM2 tires out about 2.5 inches. I had some rubbing when backing out under compression but nothing serious. But with that much lift, the tires looked good so no issues there.
As far as mileage, I lost between 1.5- almost 2 mpg with the EcoBoost which is less that what I lost with my '11 Eco with similar sized Nittos (lost about 2.5-3 mpg on average). But the Duratracs are much lighter and do not notice any loss of performance; in fact, I can break them loose under hard acceleration whereas the Nittos sort of bogged down the truck on initial acceleration.
Since I just have the leveling system on for now, I compare it to when my Plat was leveled as well.
Plat:
FX4:
My bad when I made the original post; the tires are actually LT285/60R20s.
http://www.goodyear.com/en-US/tires/wrangler-duratrac
You can run the 275/65/20s too. I put them on mine. They are just a little taller at 34.1 vs 33.5 and a little narrower.
That's true! I had considered that size because they are taller, but didn't want to go that narrow. But still a good choice for sure.
The duratracs look good in either size. Much depends on your local terrain and how much off-road your will do.
I will have to say that I really like that front light bar Desert Dawg and the more I see it I want to add a bull bar with lights or ?
No rubbing at with my setup, so no trimming either.
