tire balancing price
I noticed a weight missing from one of my wheels, bracket there but no weight. Dealer says they want $35 per tire to balance. If i don't notice any vibration , leave it alone, they say. Does that sound right.
If there isnt a vibration, Id let it be, honestly. $35 is quite rich for a single balance when you consider most shops charge $80-$100* for mount and balance. Mounting is definitely the hard work, balancing is not.
*disclaimer: I havent paid for mounting and balancing in years, so this could be a little off. I mount and balance all my own stuff.
Local tire store charges $7.50 per wheel to balance. I would get it rebalanced. In fact, I have mine balanced about every 10,000 to 15,000 whether there is a bounce or not. Tires will last longer and the bearings will be happier.
Shoot.. That's high. I purchased a set of tires on CL last year for my Oem winter wheels and a local shop charged me $25 per wheel to mount and balance them and I thought that was high
Try a local tire shop.
Goto an independent shop....bypass the dealer....
But are you sure it isn't a weight????
There are some small weights that look like the rim clip....
Like these 5 gram ones.....
That's very possible. Will look at wheel again. When I rotate I clean the inside of wheels. I would have noticed a weight in cleaning spot on driveway.
thank you for posting this so I didn't have to find a picture, lol that's exactly what I was gonna say. Ford uses weights just like these from the factory.
