OEM fog light wiring harness?
Old Nov 2, 2012 | 07:18 PM
JLonsinger2011's Avatar
So a year ago I got in an accident and ended up being able to get the bumper with the fog lights in them. I have the OEM switch, the bumper and the bulbs, but I can't figure out how to wire them up to be just like OEM, using the switch and all. This is on an 09 XLT and the wiring harness is not there. Where would I get the wiring harness? Will this do the trick?
http://www.ebay.com/itm/Ford-F-150-F...-/150504545938
Old Nov 2, 2012 | 07:47 PM
ddrumer's Avatar
Seems like the guys knows what he is talking about. With over 1000 sales and 100% feedback, I'd shoot him a note. It looks like this would do the trick. Not completely OEM, but it does come with a relay which makes sense that you would need it.
I know it doesn't help. Good luck.
Old Nov 2, 2012 | 07:57 PM
I'm just concerned as to if I will be able to use the headlight switch
Old Nov 3, 2012 | 09:03 PM
ddrumer's Avatar
Reading his description, it lead me to think you can. But he seemed like he might could answer that. . . .
Old Nov 3, 2012 | 10:07 PM
09supercrew's Avatar
You can also wire them to the parking lights with no problems. They will also work with your brights on that way too.
Old Nov 3, 2012 | 11:38 PM
I want to be able to control them with the OEM fog lamp switch. I could easily wire them up with an aux switch but that's not what I desire. That is, unless, some kind of black magic happens to where they only turn on when I pull the **** out? How would I go about wiring them to the parking lights?
Old Nov 5, 2012 | 09:45 AM
Just tap into the wires going to the orange light bulb in the bottom of the headlight I have had mine this way over a year and have driven from dusk till dawn and have never had any problems. I too bought the fog light switch and was going to do a "factory Install" but it proved to be just impossible at the time I wanted them on all the time anyway and with the brights so this nuch easier took like ten minutes and I was done. I bought the plug & pigtail for the back of the fog lamp on E-Bay. Hope this helps.
