2013 F160 daytime running lights
Old Oct 21, 2012 | 03:46 PM
cdmm151's Avatar
2013 F150 daytime running lights
Can anybody tell me if the 2013 F150 that have the HIDs be programmed to have the daytime running lights like the previous models?
Old Oct 21, 2012 | 07:20 PM
semperfif150's Avatar
According to page 92 of the 2013 F150 manual it states:
The system turns the headlamps on with a reduced intensity output
(halogen headlamps) or turns the front turn lamps on (HID headlamps)
in daylight conditions.
To switch the system on, ignition must be in the on position, then switch
the lighting control to the off, autolamp, or parking lamp position.
Here's a link to the whole manual:
http://www.motorcraftservice.com/pub.../13f12om1e.pdf
Old Oct 23, 2012 | 11:05 AM
cdmm151's Avatar
Can't down load because I need a log in.
Old Oct 23, 2012 | 11:57 AM
It's a direct link... no login required.
Old Oct 23, 2012 | 03:43 PM
LNCHBOX's Avatar
Login is required for me as well.
Old Oct 23, 2012 | 03:51 PM
https://www.fleet.ford.com/maintenan...ls/default.asp
Try that link then and put in the year/model etc... no login required... which takes you to the link above. It must set a session variable to allow access from the fleet website and not a direct link.
Old Oct 23, 2012 | 08:12 PM
Damn Dirty Ape's Avatar
http://www.fordowner.com works as well.
Old Mar 23, 2013 | 12:14 AM
DANACO's Avatar
None of the links above work for me, any other information that will allow or lead me to get the DTRL's system operational ? Is it actually possible ?
I just bought a new FX4the other day with the HID's and would really like to have the turn signal running lights working. I did this on my previous 07 Tacoma I just traded in, that was a few relays, pretty simple except for a few stripped knuckles ! That was a really good truck but was needing something bigger, I think anyway ! I did not like the Tundra at all, the FX 4 is pretty cool, I hope it works out well for us.
Old Mar 25, 2013 | 08:01 AM
cdmm151's Avatar
You need to take it to the dealer and he programs them.
Old Mar 25, 2013 | 09:13 AM
take it to the dealer....they've got to program it for ya....
Old Mar 25, 2013 | 12:44 PM
High-ster's Avatar
In order to have the turn signals act as running lights takes an added aftermarket module.
Headlight DRL's can be programmed by the dealer (for a slight fee).
Old Oct 29, 2013 | 06:36 PM
BlackToothFx4's Avatar
does anyone know if they will disable them? im looking to upgrade to the factory HID projectors
