Turn Signal Flashing Fast
Ok I have a 2010 F-150 FX4 and I noticed the other day, that when I turn on the right turn signal that it blinks really fast. Meaning that a bulb is about to be bad?
So how do I know if it's the front or rear bulb that's about to go out?
Yes most of the time this means the bulb is about to go bad. It could also be the relay switch but most often is simply a bulb.
When the light comes on it fills with voltage and creates resistance which then triggers the relay to turn off. When the bulb is about to go out it doesn't provide the proper resistance and will cause the relay to switch on and off quicker.
Another thread states when the rack and pinion go south (on the 11's), the turn signals fail to operate.
So if you had an '11, I'd say a rapid blinker means the tranny is gonna grenade.
Depending of course if was the right or left, front or rear.
^ only on the EcoBoost trucks because apparently there are tons of motor problems that everybody is having
WOW the good and the bad offset each other. oh what to do...........................oh me...... oh my....... what to do
Well.
I spent all day trying to figure out why my truck (after I installed front 3157 LEDs) had hyperflash on the left side, but not on the right side. I installed different resistors, switch the bulb sides and nothing. (almost 2 hours testing, cutting wires a making connections) Then I joined this old forum and BINGO. The rear have 2 damn bulbs in each side "I forgot that there's two flashing lights in the rear" (the bottom one was dead) . So I feel a lot more dumb than you do now.
Your small mistake save my day
Thanks a lot
Thanks a lot
SIr 2013 F150 Raptor Hypre Left turn signal. Was intermittent now a few weeks later constant. Will buy bulbs back and front as well as relay switch. Where can i find the relay switch? I could not find a flasher as my older vehicles had. Thanks
