BDS 2.5" leveling?
Raptor blocks are 2.5" and you can order them through your local Ford Dealer...
or www.tascaparts.com where they are $59.xx per side.
I just installed the bds 2.5/1 on my truck and pondered getting the 2" autospring block instead too. However, after installing the rear block, I don't see it as much of a risk. The 1" block bolts directly to the leaf springs with two center pins. Then the original block is placed between this assembly and the axle with the u-bolts.
I don't see why that would be any different than an add-a-leaf.
I've looked and looked on that website and can't find the blocks. Do you have a more exact link? Props in advance!
Cosmo
Hopefully this link works...
http://www.tascaparts.com/parts/2011...=131&maxRow=10
The last 2 items labeled "U-Bolt Spacer" Part #6 on the diagram.
(I think - 90% -ish sure. I would call and double check before I placed my order)
