Sponsored by: DashLynx
Is CAB-BUS be programmed to add a device?
Old 04-26-2012, 10:24 PM
Formula jg's Avatar
I replaced the OEM radio w/Sirius with an aftermarket nav/dvd head unit but lost the feature that kept radio and Sync on for 10 minutes after turning off the ignition or a door was opened whichever came first (I love that feature).
On any oem system other than base radio this accessory delay was controled by CAN-BUS. So can it be programmed to add a device?
If not my 2nd option would be to add a relay to the radio ground wire in the oem gray radio plug and run it directly to accessory delay fuse 41 but I'd rather go the CAN-BUS route.
Thx
Quick Reply: Is CAB-BUS be programmed to add a device?
