2012 FX4 Luxury, view tire pressure?
Old Mar 28, 2012 | 09:34 PM
hohlraum's Avatar
Anywhere on the control center or nav to view the current tire pressure?
Old Mar 29, 2012 | 06:13 AM
ryanwagner78's Avatar
Check the manual, but I don't believe so.
Old Mar 29, 2012 | 10:52 AM
Gerrard155's Avatar
No, its one of the few things that I missed moving from my silverado to the F150
Old Mar 29, 2012 | 10:54 AM
No, it just tells you when a tire loses pressure.
Old Mar 29, 2012 | 11:11 AM
Gipraw's Avatar
and not even which tire.
Old Mar 29, 2012 | 11:43 AM
hohlraum's Avatar
Ugh. Might have to put an aftermarket tpms in there at some point. I think the newer trucks put the sensor in the hub so should be ok to use a stem based aftermarket.
Old Mar 29, 2012 | 11:47 AM
The 2011s have the sensor in the valve stem, did the 2012s change?
Old Mar 29, 2012 | 11:53 AM
hohlraum's Avatar
If so band based would work as well I guess. Gotta take the tire off for either solution I guess.
Old Mar 29, 2012 | 12:37 PM
nards444's Avatar
the monitors are there as I beleive its required by law now. Another thing Ford lacks in design behind chevy in NOT telling you the actual pressure just warning you when they are low.
