need tire sizes.
need tire sizes.
i am going to install AS 2.5 lift w/add a leaf on my 2011 xlt this spring,my factory tires are p275/65r18,i would like to get 35,s on after lift is installed,my problem is... i don,t want to go wider due to the pa. law that states,all tire tread must be covered by fender,i really don,t like plastic fender flares.any suggestions on tire sizes?
you really went back and edited this post before you "forgot space" but yet you didn't edit the terrible grammar and run on sentence?
and onto your question, does it have to be a 35" or is a 33-34 allowable? finding a true 35" tire around 11-11.5" wide is going to be pretty hard. If you can settle a little bit on height you will have much more possibilities.
do they enforce the tire law much in your area? a 12.50 won't stick out much at all if you are running stock wheels. if you change your wheels chances are you will need flares.
