Wacky intake air temps
Old Jan 25, 2012 | 08:22 AM
bohnman's Avatar
to find the location, just follow the intake before the turbos and look for the sensor.
See that is the part I'm not sure about I've read that it's part of the MAF right after the filter and then I've also read that it is right before the TB because then you get the temp after the intercooler which makes more sense to me. I think I may turn the key to run when I am getting a reading and disconnect the connector and see which one makes it turn off.
Old Jan 25, 2012 | 08:33 AM
nards444's Avatar
just because you turn it back to stock doesnt mean the dealer isnt going to know.
Old Jan 25, 2012 | 09:20 AM
Originally Posted by bohnman
So I've got 6k on my 2011 Ecoboost and have installed a couple additions bullying tuner and AEM cold air intake the truck runs great but I keep noticing that my intake air temp is going from a normal reading of 30-70 degrees then like a switch it falls flat to 0 and doesn't budge then maybe 10mins to an hour all of a sudden it will read normal again for 5mins then back to 0.
I really dont want to take it to the dealer because there is no intake air temp gauge in the truck stock so how do I explain my situation? My real question is does any body had the part number for the sensor and it's location? I'll just buy the sensor from Ford and install it my self.
I'm thinking that this could be making the truck run rich and wasting has.
Sounds like a bully dog issue.....contact them and let the know so it can be fixed....something was overlooked during their beta testing....
Old Jan 25, 2012 | 10:24 AM
str8t six's Avatar
well i know on the lightnings that they have 2 IAT sensors, one before the intercooler in the air box and one after inside the intake manifold.
Old Jan 26, 2012 | 01:26 PM
bohnman's Avatar
Yea I just figured that out. I've been on the phone with bullydog now an they think it's the tune.
Running with stock tune for now
Old Jan 27, 2012 | 07:57 PM
Mikey340's Avatar
Get a custom tune and sell me the bully for my new truck! Problem solved
Old Jan 29, 2012 | 07:15 PM
bohnman's Avatar
Well I've made some observations. 1st the bully dog tune has been removed and I'm only using it to monitor functions.
2nd the intake temp switching to 0 happens on a stock tune as well. It seams that the intake temp operates fine until it goes below 32degrees then like a switch at 32 or below it just flat lines at 0. I'm starting to think this could be some of the bad milage that people have been reporting with the eco's in the winter. Because it seams when the truck goes to 0 it runs rich. I just wish more people could confirm that this is also happening to there trucks.
Old Jan 29, 2012 | 08:11 PM
str8t six's Avatar
maybe your computer needs to be reflashed by ford?
Old Jan 30, 2012 | 07:54 AM
bohnman's Avatar
I doubt it it was just in for a major transmission over haul 2 weeks after X-mas.
Old Jan 30, 2012 | 10:02 AM
str8t six's Avatar
well something isnt right if your IAT cant read past 32 degrees
