2011 Platinum Running Board - Delay !!
I have 2011 Platinum bought it last November.
Yesterday I disconnect the battery for 1 hour to wiring my off road lights.
After finished the work I noticed that the power running board delay to go in when closing the door for 10 seconds and I think it shouldn't delay more than 2 seconds, right?
I have used the reset system but nothing changed. Any help please.
You are correct the delay s/b about 2 seconds. I'd try turning the system off via the message center and on again several more times or even disconnecting the battery for a short time again and see if that makes a diff??
http://ww2.justanswer.com/uploads/AP...4_pbr_test.pdf
I had a platinum previously that had running board issues. The system would reset randomly and they would not deploy. Other times I would set it to leave them deployed for washing them and they would just randomly go back up. Sometimes they would delay pulling up, I guess I wasn't the only one with those issues.
All the more reason I went with the FX4 this time, less automation, less **** to break.
you know I honestly had this thought cross my mind prior to buying this truck and it has been nothing but problems
well I have an appointment with the dealer on the 28th of may so I will have to keep you guys posted ....
jtrude, don't despair, I'm sure you will get it worked out, unfortunately things sometimes break. I've had two Plat's an '09 & my current '13 and never had an issue with the PRBs...in fact they are one of my fav features about the Plat, the truck looks so much cleaner without the fixed running boards (IMO).
Thanks for keeping positive I just have seemed to have the most bizarre issues with this truck that really makes you think it was built on a Friday or a Monday every 3-4 weeks its been in for something stupid ... I will let you folks know what the out come is next week
Well I got the truck back earlier this evening and like I said I would keep you updated with what the issue was they wound up replacing the d/s power running board module on the work order they described it as being behind the rear seats and trim ".... Remove rear seats and related trim replace PRB module and test ..." She's all back to normal now ... Hope this helps
I agree on the clean looks. I just added Amp Energy boards to my '11 F150 because I hated the factory boards so much.
