2011 fx4 level + tires
Old Dec 19, 2011 | 05:52 PM
Fishhunt17's Avatar
Hey guys, i put a level on my truck, im looking at getting bf all terrains 325/65/18 stock fx4 wheels.. does anyone have this setup and am i going to have any kind of rub?
Old Dec 19, 2011 | 08:18 PM
06yz250f's Avatar
click link in my sig.
Old Dec 20, 2011 | 01:31 PM
wandell's Avatar
That's not a great idea. The 325/65-18 is basically a 35x13.00 tire, which is too wide for the stock 7.5 inch wheels. BFG's 305/65-18 is basically a 34x12.50 tire and would be a much better fit. Even these are pushing the limit for the OEM wheels.
Old Dec 20, 2011 | 03:41 PM
Trev18's Avatar
I have the 305/65/18's on the stock rims and I don't think there is room to go any wider.
Old Dec 20, 2011 | 04:46 PM
nathan08fx4's Avatar
FishHunt17- I have a 2011 Fx4 S.Crew with 2 1/2 inch leveling kit and a 1.5" Add a leaf in the rear and I am running 305/65/r18 BFG A/T's. When I am half-full turn the tires are catching the stock wheel lip moulding. Other than that, I have to other issues. My 2008 F-150 with the same setup never hit anywhere.
Old Dec 23, 2011 | 09:36 AM
That's unusual because you should have more clearance on the '11 then the '08 in the wheelwell's.
Old Dec 23, 2011 | 10:10 AM
PAWPAW- I thought that too until I seen it with my own two eyes. They are making these trucks too much like cars anymore! LOL.
Old Dec 23, 2011 | 02:32 PM
Trev18's Avatar
That's odd. I have the exact same tires with no rub without the leveling kit and no rub with the leveling kit. I also thought the 2009+ f150's had .5" more space than previous years. A 1.5" leveling kit should get you the same result as 2" leveling kit on a pre-2009 F150. I'm basing this on the 2 trucks I've owned so I could be wrong about the second part but I know I had no issues with the same tires
Old Dec 23, 2011 | 04:13 PM
Big_Smokey's Avatar
Hmmm? that is weird. Im almost certain the wheel wells are bigger.
Give us a pick of what you are talking about. Im trying to get what a
"stock wheel lip molding" is? Or maybe ive never called it that.
Old Dec 23, 2011 | 04:47 PM
NASSTY's Avatar
You running stock wheels or aftermarket with less backspacing?
Old Dec 23, 2011 | 05:59 PM
Njb5509's Avatar
[IMG][/IMG]
2.5 level which was 2" in front and 1 inch in back with 33x12.50x20 toyo open country M/T
20"x8.5 10mm offset rockstars
Old Dec 23, 2011 | 06:01 PM
Njb5509's Avatar
[IMG][/IMG]
No rub at all ... Bumps anything no rub was thinkin was going to have to cut plastic but lucked out
Old Dec 23, 2011 | 10:52 PM
06yz250f's Avatar
looks good. Remove the center caps and truck will look perfect IMO.
Old Dec 23, 2011 | 11:20 PM
Njb5509's Avatar
Was gonna like em way better with on love home stars in center
Njb5509's Avatar
And teu have 12 holes instead of just 6 so would look like ****
