Homelink addition?
If you have the Charcoal interior this will help you.
https://www.f150online.com/forums/20...r-openers.html
I forgot to answer your question. Yes the wiring is there. If you have the illuminated mirror than without a doubt it's there. It uses the same power connection. I would imagine the connection is there in every truck. I mean the connection is there for the trailer brake controller so I can't see why this wouldn't be but who knows just pull two bolts and find out for yourself.
If you have the illuminated mirror it uses the same plug. I'm talking about the OEM visor, not the Homelink module.
i'd try and do the mod, it's ALOT cheaper and isn't hard. Takes about an 1-1 1/2 hours and cost $20 and it will look/be factory.
I've done 3 or 4 now, it's pretty straight forward and well worth the savings to try it on your own first.
I thought I read one somewhere, that discussed how to get the visor apart and where to purchase the module.
google escape city homelink install and a link should come up. It's very straight forward, a little intimidating the first time but overall very simple.
you need to make sure you buy the right homelink, rolling code vs. non rolling code. one of those works on both, the other only works on like neighborhood gates not garage doors. Its says in the thread tho.
Good idea. I didn't like how the guide said a screwdriver, not the Escape City guide. I should of thought about it more, but that's my fault, so I ended up ripping my fabric. Oh well, my OEM one should be here by the end of the week. It's only money right? LOL
