F-150: Motor Trend's Truck of the Year!
Old Dec 13, 2011 | 03:42 PM
nards444's Avatar
Originally Posted by glc
Doesn't matter which engine you have and what the "tow rating" is - towing 10k with a 1/2 ton truck will almost always put you over one of the other limits - such as GVWR, GAWR, and/or payload. The max tow rating is under artificial ideal conditions - 150# driver, 1/4 tank of gas, NO cargo or passengers whatsoever, and minimum tongue weight.
I think you need to check out some forums where people are towing boats because this truck is getting bought and used big time with great success.
GCWR on my truck is 17,100 Truck weighs about 5 boat weighs 10 so Iam 2k under that.
GVWR for my truck is 7700. Truck weighs 5, tongue weight on my boat is under 600 but well still say 600. Four people at 200lbs which is very liberal for us, and say 200lbs of gear, and Im only at 6600lbs with another 1000 to spare. I agree you have to be careful but you are well under the ratings if you are smart. And most people tow their boats an hour or less so it doesnt matter. heck I have seen 33ft Bajas being towed by 2003 Tahoes at the launch,
Old Dec 13, 2011 | 03:58 PM
fordmantpw's Avatar
Just because people are doing it, doesn't mean they are within limits.
And, you may want to weigh your truck if you think it weghs about 5. Try closer to 6, if not over 6. Plus 4 guys, 200 lbs of gear, tongue weight of 600, 200 lbs of gas, plus all the features on your truck...you are over weight.
Check the payload sticker on the door jamb of your truck...
This is the reason I drive an F250. The F150 would pull the load no problem, but I would be overweight with my fifth wheel, and I wouldn't feel safe putting my family (or others) in danger by trying to get the truck to handle more than it should.
Old Dec 13, 2011 | 04:07 PM
bluegreenf150's Avatar
Originally Posted by Rambo
2) What's more, EcoBoost towed a 8,250 lb trailer and hauled a 1,275 lbs.
The 5.0 towed a 6,900 lb trailer and hauled 1,185.
If they want to make a valid comparison on mileage, use the same cabs and use the same trailers.
Amen. I hate when they do that! Regardless they did like the EcoBoost better than the 5.0. Did you see the accompanying video? They said when you start using the Toyota Tacoma as a truck, it starts to fall apart. LOL!
2012 Motor Trend Truck of the Year Competition Video
http://www.motortrend.com/av/of_the_...#ixzz1gS0ZTi2b
Old Dec 13, 2011 | 04:12 PM
Smokewagun's Avatar
I've lived it... Twice. Never again. If I do, I'll make changes to what I tow. My 6500# TT will max me out every time with my family and minimal in the bed. Like said above, you can't just subtract weights from the max trailer weight and be good to go. Payload of 1,600# runs out quickly for a loaded family weekend.
Old Dec 13, 2011 | 04:24 PM
fordman, What is the payload on your F-250?
We can get a pretty good payload now on a F-150 SuperCrew now with heavy payload. But most people will just buy whatever they find on the lot and won't bother with doing homework and getting the right truck for the job.
Old Dec 13, 2011 | 04:33 PM
nards444's Avatar
Trust me I did my homework. GVWR is 7700 payload is 2020, so assuming trucks curb weight is then 5680, thats curb weight, curb weight is everything, fuel oil etc. I now have 2020lbs to work with 4 dudes at 200, 600lb tongue weight is 1400 that leave 600lbs for me to play with. Boat weighs ten truck is 5600 still under that 17000 GCVR weight but 1500 lbs.
But lets be realistic, its my wife and I and a beach bag so 600lb tongue weight plus us and bag maybe 1000lbs there. Well under the payload limit. Boat and trailer realistically weigh more like 9500 because I never tow with a full tank, so now Im back over two grand to spare for total carrying weight. And guys with the same boat as mine think have said the tongue weight is more like high 4's to low-mid 500's. You do have to do your HW and be careful like you say, but its toatally feasible and safe in these trucks.
Old Dec 13, 2011 | 04:39 PM
nards444's Avatar
2011 Super cab 4x4 is just over 3 grand I think, so I mean were not talking big numbers here although 1000lbs is a lot. and if your talking an older diesel your only getting like 2500lbs of payload. So these new 1/2 tons are not your daddys half ton
Old Dec 13, 2011 | 05:15 PM
troutspinner's Avatar
It's not about how much it can tow, it's how it does it. Load a 5.4 or a 5.0 with a 6 or 7k lb. trailer, they both do fine. Do the same thing with an Eco and it's child's play, the engine just chugs, no extra revs or whining, it's effortless.
Old Dec 13, 2011 | 07:14 PM
If you have a 10k boat and the tongue weight is only 600, that is very unsafe. Tongue weight should NEVER be less than 8% of the gross weight and should not be more than 15%, with 12% ideal.
Old Dec 13, 2011 | 09:00 PM
fordmantpw's Avatar
1999lbs, and I'm pushing that loaded with my fifth wheel and family for the week.
Old Dec 13, 2011 | 10:45 PM
That's not bad, but I thought you were going to say a higher number for a F-250. The 2012 F-150 SuperCrew is rated at 2310 lbs in the book in 4x4 and over 2600 lbs in 4x2. We haven't seen any payload stickers yet for the new heavy payload SuperCrew F-150, but I have to guess they will both be easily over 2000 lbs with options. It's a good time to buy a F-150.
Old Dec 14, 2011 | 07:52 AM
nards444's Avatar
Like I said truck in door jam states 2020 for payload, so whats the sense in a diesel in anymore.
Old Dec 14, 2011 | 07:57 AM
06yz250f's Avatar
I know if i was towing much more weight (6-6500lbs right now+gear) i'd have gone with a 3/4 ton instead. No sense in nearly being maxed out, and for bigger trailers a larger truck would be nice.
Old Dec 14, 2011 | 07:59 AM
nards444's Avatar
I am sure whoever built the trailer knew what they were doing as the trailer was specifically made for the boat, plaquered and everything. I have a fountain and fountain is not going to put a walmart trailer under a 150k boat. Let me clarify when I said boat i meant trailer and boat together. Boat weighs 7k, trailer weighs in around2300-2500lbs..
Dont quote me but I dont think your going to see any tongue weight above 600lbs on anything until it gets to be really big because as far as I know any F150 or F250 is only able to tow 600lbs of tongue weight. basically what your saying is anything over 5-6klbs would be untowable for most of the trucks on the road.
Old Dec 14, 2011 | 08:03 AM
54regcab's Avatar
What people have to start understanding is not the MPG, but the fact the truck can tow what it can tow. I am getting 16 in the city or so, 21 HWY, which is awesome coming from a diesel. Towing my 10k boat I get 10, my diesel only got 11. Hook up that 10k boat to that 5.0 and check it out once.
I too am kind of disapointed in towing MPG, but look until this configuration nothing could tow 11,300 and I was stuck with my F250 paying out the ace for fuel and Maint.
Flat out there is nothing on the market in this class that has the peformance that this has with the MPG's. So I say to spend money on a V8 just because of the sound is not worth it.
Like it or not MPG's is going to dominate car building, not only because of CAFE but because of peopls wallets, we will not see $2 a gallon ever again, I doubt we see $3 a gallon either. Rumor is chevy will have an ecoboost out next year with its totally new line up and dodge is working on something. As much as I love the American V8 I think its going to go by the way side, these turboed engines are only going to get better.
The US needs to get with it and put diesels in more vehicles like they do everywhere else in the world. In Europe many cars can and are bought as diesels, why such a delay in the US? I'm not sold on turbo gasoline engines until I start seeing 100K+ out of them.
