I don't have my high beams on, stop flashing me!!!
I hadn't thought that it was a problem with alignment. I really just thought that the lights were brighter. I see some pretty bright headlights on other vehicles.
I did remove the blocks on the rear leaf springs to level the truck. I've only got about 6500 easy miles on this truck.
I'll have to check the alignment to see if there's an issue.
yea i know thats why im being flashed....and wittom its the same problem for you if you removed the blocks in the back, your headlights are shining a little more upward now so its right in their eyes.. im gonna adjust my headlights this weekend
I don't get flashed by oncoming cars but boy do I light up the interior of cars when I'm behind them due to the leveling kit (BTW I did re align and its just the height of my truck to their mirrors when I'm behind them)
It's going to be a problem with ANY vehicle that's been lifted or leveled without a proper headlight realignment. Mine is dead stock with Silverstar Ultras and I get flashed when I tow a 3500# trailer with no weight distribution or suspension assist.
Was at the dearlership for an oil change today and had them align the headlights. They did it under warranty even after I told them I removed the blocks.
I posted this here because my truck is a 2011. I thought that the problem might have been unique to the 09-12 trucks. I've learned from the replies that my issue is a result of my removing the blocks from the leaf springs.
Is this a '09-'12 problem? or earlier models...kind of confused by the replies here
After I installed a 1.5" level I have started to get flashed every time I drive at night. Last week I was actually flashed by a Semi. I've tried to lower the beams but no matter how much I turn the adjustment screws the lights will not lower.
You sure you are turning the adjuster? They are a little tricky. It may feel like you are turning it, but you could be just spinning the screwdriver over the top. I was doing this until I looked at the way it was set up. Use a flat blade screwdriver and be sure it is actually making contact with the tab that gets turned. This may not be your issue, but I would be surprised if it was all the way lowered from the factory. They need to have some leeway in them to adjust for different loads. You may also be able to bring them down a little moving the whole housing. I believe it is held by three 10mm bolts two at top, one behind the flexible rubber cover. Loosen them and pull at the top of the housing toward you then re-tighten while holding it in place.
I believe you are right , I was going by my memory and should have looked. The thing to check for is to make sure it is actually spinning the adjuster and not just spinning in the hole over the top of the tab.
Thanks for the correction.
