fog lights
Old Nov 7, 2011 | 09:31 PM
Richmoto125's Avatar
fog lights
does anyone know where to get fog lights i melted mine! and i can't find any anywhere!! how about projectors??
Old Nov 7, 2011 | 09:48 PM
Raptor05121's Avatar
Ford dealer would be best. I dont know of any aftermarket lights for the new trucks yet
Old Nov 7, 2011 | 09:51 PM
yeah i went to my dealer and they said they are on backorder..... i can't believe it!
Old Nov 7, 2011 | 10:00 PM
http://www.drivewire.com/vehicle/200...150/fog-light/
Bottom of page....
Old Nov 7, 2011 | 10:04 PM
Originally Posted by 88racing
thanks bro!
Old Nov 7, 2011 | 10:18 PM
OP, how did you melt them?
Old Nov 7, 2011 | 10:22 PM
Originally Posted by raptor05121
op, how did you melt them?
x2!...
Old Nov 7, 2011 | 11:22 PM
kingfish51's Avatar
My guess is used a 9005ST in them instead of 9140/9145.
Old Nov 8, 2011 | 11:22 AM
I hope not. I've got that warning plastered all over my write-ups page.
Old Nov 8, 2011 | 02:09 PM
J T Ford's Avatar
Are the 9040 and 9045 the same?? My manual calls for 9040's, but I have seen on this forum that the number is 9045????
Old Nov 8, 2011 | 03:06 PM
kingfish51's Avatar
Either the 9145 or 9140 will work. I run the 9145ST Silverstars with no problem.
Old Nov 8, 2011 | 08:32 PM
Here ya go. Searching goes a long way.
9140- (40W @ 900 lu/H1.5) H10 not a good upgrade bulb, and OEM for some fog lamps. Next step: 9145
9145- (45W @ 1100 lu/H2) H10 bulb. Can be used as an upgrade from 9140 for slightly more light output without risking melting. Next step: 9155
9155- (55W @ 1350 lu/H3.5) H10, great upgrade (if you can handle the heat) from 9145. Next step: 9005
9005- (65W @ 1700 lu/H5) This is a great upgrade for those with metal/glass fog lamps or large housings. Next step: 9011
9011- (65W @ 2350 lu/H5) This is the HIR1. Can be swapped in place of the 9005 with minimal cutting. No heat increase (in comparison of 9005).
9006- (55W @ 1000 lu/H4) This would be used in the stock 1997 & 1998 F-150 fog lights. You can swap to the higher-output HIR2 9012 bulbs or use a different brand 9006 for more power. Next step: 9012
9012- (55W @ 1870 lu/H4) HIR2 bulb. Can be swapped in place of the 9006 with minimal cutting. 55W @ 1870 lumens. No heat increase (in comparison of 9006).
H3- (55W @ 1450 luH3) 55W transverse bulb. You can upgrade to 100W H3, but caution for heat. Next step: H3C HID.
H1- (55W @ 1550 lu/H3) 55W axial filament bulb. Can be upgraded to 100W H1, but caution for heat. Next step: H1 HID
