[Update]I have over 500 miles is that enough to race it.
Old Aug 8, 2011 | 12:01 AM
Mark Miller's Avatar
2011 F-150 XLT Supercab 4X4,EcoBoost,3.55 LS axle.It just turned 700 miles as i was leaving the track.
First pass brought it up against the converter just about 1,200 rpm
60ft. 2.473
330ft.6.5589
1/8 Mile Et.9.9018
1/8 Mile MPH 73.67
1000' Et.12.7625
1/4 Mile 15.1628
1/4 Mile MPH 93.50
Pass number 2 just left off idle didn't like that
60ft.2.6344
330ft.6.7438
1/8 Mile Et.10.1164
1/8 Mile MPH 72.75
1000' Et.13.0154
1/4 Mile Et. 15.4429
1/4 Mile MPH 93.07
Pass number 3 last pass of the day brought it up to about 1,500 rpm against converter[Reached my goal for the day]
60ft.2.2623
330ft.6.3124
1/8 Mile Et.9.6702
1/8 Mile MPH 73.22
1000' Et. 12.5593
1/4 Mile Et. 14.9779
1/4 Mile MPH 93.25
It was 81 degrees during the last run humidity seemed pretty high,track elevation is 1,100 ft. above Sea Level.
Later Mark.
Old Aug 8, 2011 | 12:35 AM
SLW-SVT's Avatar
TRUCK OF THE YEAR - 2011
did you turn traction control off?
Old Aug 8, 2011 | 12:45 AM
No.
Old Aug 8, 2011 | 02:10 AM
tbear853's Avatar
That's some pretty good numbers there ! I'm impressed. Stock truck, low miles, that's gittin'er done.
Old Aug 8, 2011 | 04:05 AM
ruffn-it's Avatar
Well....did you race any chebys?
Old Aug 8, 2011 | 09:04 AM
APT's Avatar
APT
Were there any stock trucks you did not beat? That's a great time for 2WD and traction control on.
Best times seem to be starting in 4WD, bring RPM up to the highest it will go (torque converter stall speed) which I hear is around 2000rpm. Then shift out of 4WD after the 1->2 shift.
Old Aug 8, 2011 | 09:38 AM
Arctic Cat F7's Avatar
Stupid question time but should or could you run a drag race in 4 wheel high?? I would be terrified of blowing my 4X4 system. (High speeds and high revs)
Old Aug 8, 2011 | 11:54 AM
tbear853's Avatar
But it would be a great way to test the system's ruggedness ...
... and your warranty I think?
Old Aug 8, 2011 | 12:25 PM
ajrothm's Avatar
Damn good numbers considering the DA and the fact you are just starting out. As someone else mentioned, you HAVE to launch it in boost. You need to get on the converter until you hear it spooling up....about 2000rpms is all I can get before it starts to spin. I would turn the traction control off and on the last amber light nail that sucker.... On a sticky track it should hook or barely spin (which may actually help it a bit).....if it does spin, try 4hi. Matter in fact, you may be able to build more boost on the line in 4 hi with all wheels getting power.... It needs all the boost you can get on the line. I bet 2.00 - 2.10 60's are obtainable..... That would have been 14.70 or so that night for you...
I will be racing mine next weekend and trying some different things and see what it does.... Mine has a leveling kit, 20"s and 305/55s so is pulling more weight, more wind drag and it's hurting the gearing some... I hope I can still get in the 14s even with the wheel handicap..
Old Aug 8, 2011 | 01:15 PM
Nice numbers....glad you didn't break it....
Old Aug 8, 2011 | 01:19 PM
Wookie's Avatar
^^^ Like he said. In my unofficial back roads launch tests I have found that my truck will run the best when I hold it in the 1800-2000 RPM range with the TC off. Lift off the brakes as I roll into the throttle. This lets the tires spin just a little bit to get the revs up. Much more than 2K and the tires spin too much. Good results though, how many chevys did you kill? Even more importantly did you get the chance to crush a tundra?
Old Aug 8, 2011 | 01:21 PM
APT's Avatar
APT
Switch back to 2WD after the 1-2 shift (which cannot be more than 40mph).
While I've driven at 65mph in 4WD high, I'm not sure I'd do 90+ on a dry track, even straight.
Old Aug 8, 2011 | 04:46 PM
hydro1's Avatar
In our F-250's we left them in 4hi all the way down. Some Spartan tuned trucks go over 110 mph with no driveline issues.
Somebody here (forget his name) has a red Ecoboost who left it in 4hi all the way and 2000rpm boosted launch and pulled off mid 14's (all stock).
Old Aug 9, 2011 | 12:47 AM
I raced a GMC S-15 pickup but it had a V-8,open headers and slicks he ran a high 12.Then i raced a Mid 90's Cougar XR7 Supercharged V-6,5 speed he ran a high 14 to my 15.44 on the second pass.The 3rd pass i ran solo no one in the other lane.To tell you the truth there were no newer Chevy or GMC full size trucks racing and no Toyota's as it was Ford VS Gm.Maybe they new i was going to be there with the EcoBoost and were afraid.
Thanks Mark.
Old Aug 9, 2011 | 01:08 PM
Wookie's Avatar
I've been thinking about the 2WD vs 4WD launch question. To me if you want to launch in 4WD I would make sure the from end is locked up well before I get to the starting line and leave it there until I lift off the gas. The manual says there is not a top speed for 4WD but it can not be engaged at more than 55 or 35 when really cold. Once the front end is locked up I would not try to unlock it while putting down maximum power. That just seems like it would be rough on the hubs, transfer case and disconnects.
