Heads
If I was able to get a set of heads off of a Mustang GT or Crown Vic P71 PI.
Would they bolt up to my 2010's 4.6L V8 and if so, what kinda gain could I expect?
I'm looking to add a little more get up and go off of the line.
I'm waiting to find the right exhaust and most likely a tuner of some sort.
What are the best mods you guys have personally used or have seen someone else use?
Thanks,
Tony
Thanks,
Tony
2010SXT4by4 - If I was able to get a set of heads off of a Mustang GT or Crown Vic P71 PI. Would they bolt up to my 2010's 4.6L V8 ...
...and if so, what kinda gain could I expect?
Unless ... You use the Mustang GT / Crown Vic PI heads as an opportunity to have them massaged while you're driving with the existing heads.
The HP / torque differences between the Mustang / Crown Victoria / F-150 PI engines is either MAF size, throttle body, intake manifold, presence of knock sensor, exhaust configuration, ECM tune, and/or a combination thereof.
BTW ... There is absolutely no difference in the heads of a P71 and any other Crown Victoria ( P70, P72, P73, P74 ). All 2001+ are PI.
For you reading enjoyment and listening pleasure ...
A couple of (IMO) good articles that will explain the various nuiances of the 4.6L / 281CI engines ...
