Grille LED Install
Grille LED Install
So I am trying to figure out how well this will work with the stock grille. It appears that most of these lights are behind the mesh style grille but im trying to keep it stock. The bottom opening is a little over 30" long and 1.5 inches high. The light is 30" and I approx 2-2.5" high.
Vehicle is a 2010 F150 FX4 SC.
Any thoughts?
Also if anyone is interested I have a supplier who gives a pretty good deal.
http://www.rigidindustries.com/
30" "E" Series LED Light Bar The new "E" Series High Intensity L.E.D. Light by Rigid Industries. General Specs: 93% Optical Efficiency Shockproof No Vibration 60 LED's with 50,000+ Hour Life Span Easy Two Wire Installation 8.67 Amps 117watts 10800 Lumens Patented Hybrid Technology runs lights at 90% efficiency which is unmatched in the industry. 8" of flood reflectors on the outsides of the light and 22" of spot reflectors on the inside half of the light. This will optimize both functional light spread and light distance for increased visability. Dimensions: 3.375" High 3.625" Deep 31 3/8" Long Why LED? A light-emitting-diode (LED) is a semiconductor diode that emits light when an electrical current is applied in the forward direction of the device, as in the simple LED circut. The effect is a form of electroluminescence where incoherent and narow-spectrum light is emitted from the P-N junction in a solid state material. Advantages of LED lighting: 50,000 hour life expectancy Very High Lumens per Watt No glass lens to break No Bulbs to Burn out No Ballast to Mount Rigid Industries Advantage,it's all in the reflector. Patented Super Efficient Reflector 93% efficient vs. 72% "Brand X" reflectors Available in both Pencil and Flood Beam More Light with Less Power, Heat and size. Much Father Projection Multi Source Light No "bouncing" beams Virtually eliminates HID vibration If one LED fails the other LEDs will not Greatly Reduces eye fatigue
Any thoughts?
I havent seen any F150's around here with the light mounted behind the grille, although I have seen multiple current gen expy's with them around here. I would assume it works alright, but if your opening is smaller than the height of the light you will probably lose a bit of your light output. What type of cost are you looking at for those? I may be wrong, but I think those 30" ones retail for like $1k? just curious, I was looking into getting either a 10 or 12".
Easily, but you'd still be spending around 800 dollars and getting less light. These are snazzy and all, but this isn't what I'd call a civilian mod. The only place I've seen this LED light bars that made sense were as landing lights on small aircraft.
I just installed the 10" rigid led bar. I have go to say that it is amazing. You have to get past the sticker shock at first but when you see what just the 10" light can do it is totally worth it. I was about to get the 20" and put it down in the bumper with the kit that they make. Did you consider that option before your purchase? That 30" has got to be BRIGHT! I Mounted my 10" on my Ranch Hand Grill guard. It looks nice but I might consider getting rid of the guard sometime. The only thing I can suggest is one of those smittybuilt light bars. Im sure you can fab something up. I wouldn't mount that behind the grill because you would loose a lot of the light. Is that the spot beam or flood or combo. It sure would look wicked going down the road though with all that light coming out behind the grill. Good luck to ya. PM me if you want pics of my set-up!
$1000 for the 40"
I have heard that LEDs don't throw light nearly as far as halogens or HIDs. Have any pics of the light output compared to ur headlights?
I want to put it behind the grille so its hidden. No crazy about having a $1000 light in the open. Also you can buy protectors for them that will make it black from the front when your not using it.
I think I might end up getting a mesh or billet style grille.
Sorry FX4'er. This forum doesn't save PM's after they have been read. I will just put up some pics here. Like I said first. I went with the 10" because the price was high and I want to try this before I put any money into more lights. I also have some PIAA 525s that I want to put on here as well. I am still entertaining the thought of removing this Ranch Hand but we shall see.
