Built my own blocks
The fctory blocks with tabs to hit the bump stops are cast, but on my trucks .... the saddle that's welded to the axle tube, most often called a "spring perch" ... is not cast anything.
They're stamped and formed from plate steel, and are about 1/4" thick.
Look on top of the axle, under the blocks.
The lower one isn't welded to the axle tube, it's part of the clamps that hold it all together in a stack.
