Fog Lights?
Old Feb 2, 2011 | 11:19 PM
bshipley78's Avatar
Fog Lights?
I have a 2010 F150 FX4 and am wanting to upgrade the fog lights without melting the light housing. Looking around on here and sites online i'm seeing all different sizes. I have Silverstar headlights and would like to match them.
will the H11 work?
What size are you guys using for your fog lights?
Old Feb 2, 2011 | 11:24 PM
camopaint0707's Avatar
silverstar ultras
Old Feb 2, 2011 | 11:42 PM
bshipley78's Avatar
Sylvania hasn't made ultras for the 2010 unless there is another size that will work
Old Feb 3, 2011 | 12:05 AM
josh34's Avatar
stock fog bulb is 9140
silverstar replacement doesn't come in 9140 ... only 9145 which is like 5 watts higher
also h10 works
h11 will melt the lense
also, anything other than a 9140 will cause tiny spiderwebbing in the plastic lense if used all the time
Old Feb 3, 2011 | 02:30 PM
Bama72's Avatar
Been running silverstars 9145 in my fogs since 11/2009 with any problems. I pulled all factory bulbs(kept as spares), when I first got it, and installed Silverstars where ever possible. I have yet had to replace a silverstar bulb. I run my fogs all the time with my headlights and have no spider webbing (not saying it can't happen).
Old Feb 3, 2011 | 02:34 PM
marshal's Avatar
i run 9006 ultra's in mine, just had to grind the tab down a little. my "cooler" 55watt H10 HID's melted the housings in a jiffy.
Old Feb 4, 2011 | 09:46 PM
bshipley78's Avatar
Well I picked up a pair of the 9145ST's
Quite a bit of difference
Thanks for your replies/inputs
Old Feb 9, 2011 | 03:09 AM
Raptor05121's Avatar
Covered it for anyone else wondering..
Fog lights
So, you want to increase the light output down under to fill in the black hole? You've come to the right place. Here I will let you know what is and isn't safe to run in your truck.
Most vehicles come with either the 9140 or 9145 bulb (see chart above). The only difference between the two is wattage output. The 9140 puts out 40W of power, and the 9145 puts out 45W of power with 900 and 1100 lumens, respectively. There is a reason for this madness: HEAT. Chances are, you have a plastic fog light assembly. If so, you want to stay ~20% within OEM specs to avoid melting your lights and possible risk of fire. For vehicles with larger or metal housings, you can safely swap larger bulbs.
Now, if you scroll up and look at the bases of bulb, you will see the 9005, 9006 and 9100 series fog lamps all share the same base. WRONG. They are all different (9140, 9145, and 9155 share the same base). BUT. They are SLIGHTLY different. So with some force and dexterity, you will be able to put and bulb in any socket. For example, if you have a 9145 45W bulb, you CAN fit a 65W 9005 bulb in the same socket. The only difference is a slight off-adjustment of one of the three retainer lines (see above). However, you must be careful.
Vehicles equipped with plastic, round fogs (2006-2011 F-150, exc. Raptor) should not install bulbs over 45W of power! Since they come with 9140, a 9145 would be a good swap. Do not install 9155, 9005, or 9006 bulbs, you WILL melt your housings![/b]
Trucks with the rectangular (2004-2005) or metal housings (STX) are free to increase to highest wattage available (9005, 9011)
This is a flow chart, from least powerful to most powerful halogen drop-in replacements. Heat rating (H) is on a scale from 1 to 5, 1 being coolest and 5 being hottest.
9140- (40W @ 900 lu/H1.5) H10 not a good upgrade bulb, and OEM for some fog lamps. Next step: 9145
9145- (45W @ 1100 lu/H2) H10 bulb. Can be used as an upgrade from 9140 for slightly more light output without risking melting. Next step: 9155
9155- (55W @ 1350 lu/H3.5) H10, great upgrade (if you can handle the heat) from 9145. Next step: 9005
9005- (65W @ 1700 lu/H5) This is a great upgrade for those with metal/glass fog lamps or large housings. Next step: 9011
9011- (65W @ 2350 lu/H5) This is the HIR1. Can be swapped in place of the 9005 with minimal cutting. No heat increase (in comparison of 9005).
9006- (55W @ 1000 lu/H4) This would be used in the stock 1997 & 1998 F-150 fog lights. You can swap to the higher-output HIR2 9012 bulbs or use a different brand 9006 for more power. Next step: 9012
9012- (55W @ 1870 lu/H4) HIR2 bulb. Can be swapped in place of the 9006 with minimal cutting. 55W @ 1870 lumens. No heat increase (in comparison of 9006).
H3- (55W @ 1450 luH3) 55W transverse bulb. You can upgrade to 100W H3, but caution for heat. Next step: H3C HID.
H1- (55W @ 1550 lu/H3) 55W axial filament bulb. Can be upgraded to 100W H1, but caution for heat. Next step: H1 HID
located here:
https://www.f150online.com/forums/il...ml#post4462057
Old Feb 9, 2011 | 06:19 AM
bshipley78's Avatar
Thanks... Great Info!
Raptor05121,
that is the most informative reply I have ever seen on here. Thank you for the great bit of info.
I went with the 9145ST and like the improved lighting.
Thanks again!
Old Feb 9, 2011 | 03:19 PM
Silverstar 9145s are great bulbs. Enjoy the extra 300 lumens and whiter light.
Old Feb 9, 2011 | 04:27 PM
josh34's Avatar
thanks Raptor!
Old Feb 9, 2011 | 05:32 PM
svt450's Avatar
My Chrome bumper doesn't have fog lights bu I am thinking of cutting out a space to fit in the plastic rectangle inserts in the bumper.
Any try that?
Old Feb 9, 2011 | 11:23 PM
Mike FX4's Avatar
Great info! Can't wait to swap in some 9145s.
Old Mar 20, 2011 | 11:31 PM
CoastalTraditio's Avatar
How do the 9145's match with the Silverstars?
What model did you end up getting? I have a
2010 SCREW and am looking to swap the headlights
and fog lights but I want to make sure they match.
Thanks!
Old Mar 20, 2011 | 11:51 PM
bshipley78's Avatar
Thanks!
They have been working great... I have them on all the time when lights are needed. As for matching... they look great paired up with the head lights
