aftermarket lights fogging up?
Old Jan 19, 2011 | 04:56 PM
digbyz's Avatar
my new aftermarket head and tail lights are fogged up? its been raining and freezing,constantly changing temp from 35 to 15% in central IL. so idk if its common. the tails are back to normal but the headlights are always fogged by the turn signals? WTF just spent 600$ for them
Old Jan 19, 2011 | 06:02 PM
used2vtec's Avatar
If they were sealed properly you would not have this problem. Sounds like they are not sealed all the way. May have to take them out and add some type of sealant around them.
Old Jan 20, 2011 | 12:20 PM
digbyz's Avatar
the directions the heads came with said they will fog up idk looks cheap.
Old Jan 20, 2011 | 12:23 PM
rednoved's Avatar
X2 on the sealant. I would take them off, let them completely dry out, and put sealant on the edges. It should hopefully fix the problem.
Old Jan 20, 2011 | 12:26 PM
Timelessr1's Avatar
I had the exact same problem with mine! i decided to take them off, and will be using them to do a HID retro fit into them. since they already sperated the high and low beam into to bulbs, i only have to get a single HID kit, and not worry about the high beam.
Old Jan 20, 2011 | 03:53 PM
sharper4's Avatar
Exactly which lights do you own?
Old Jan 20, 2011 | 04:39 PM
Timelessr1's Avatar
These are the ones im refering to that sucked for me...
http://cgi.ebay.com/ebaymotors/2009-...Q5fAccessories
Old Jan 20, 2011 | 05:12 PM
jpetre's Avatar
Dang it I love those.
Old Jan 20, 2011 | 05:15 PM
used2vtec's Avatar
Those light do look pretty good. Over the years I have noticed you cant beat OEM quality in terms of all parts. Most people think since they are aftermarket they are of the same quality as OEM. This is why I just purchased the HD heads and tails for my truck. I hope you can get them sealed up and dont have any moisture problems in the future.
Old Jan 20, 2011 | 05:46 PM
munro200's Avatar
How do they look otherwise for light compared to the stock lights at night .
Old Jan 20, 2011 | 06:52 PM
Timelessr1's Avatar
When I was using them....the lightout put seemed to be more then the stock units. I really did like the look and functionality of them. The only issue was the mouisture build up in them. Then when I actually decided to take them off, I realized where the moisture was coming from...there was almost an inch of water inside the bottom of them. I drilled a small hole at the bottom and drained them. Now im just going to open them, and retro fit them, and delete the halos and add LED strip lighting instead like the Audi's
Old Jan 20, 2011 | 08:36 PM
KazK's Avatar
Old Jan 21, 2011 | 05:48 AM
08stx4x4's Avatar
You payed $600 for head lights that come with instructions telling you they will fog up? Wow, you got taken bad.
Old Jan 21, 2011 | 08:14 PM
digbyz's Avatar
yes those are the lights i got from sabersport. 08STX if you could read i said i paid 600 for head and tail lights. if they where not supposed to fog, than its kind of weird that both of them started to fog up at the same time. its also weird that they both have the same problem. and yes they came with directions that said they would fog up in some weather conditions and when you start the truck and it warms up, and you turn on the head lights within 10 min the fog goes away but the fog is frozen in the lights so im screwed.
Old Jan 21, 2011 | 08:58 PM
It's really a common sense fix.
Take the lights off the truck. Get a couple of those silica packets, tie a string to each one and drop them in one of the light holes on each light. Next day clean them up really well and reseal along the seam. Wait for the sealant to dry and reinstall.
No more fog.
Honestly I have just as many problems with quality with my stock lights. It's not just an aftermarket thing anymore.
