How Much Weight?
Old Dec 26, 2010 | 08:11 PM
#16F150's Avatar
How Much Weight?
How much weight you all running in the bed to get better traction in the snow? Thanks in advance
Old Dec 26, 2010 | 08:13 PM
marshal's Avatar
280 lbs
four 70 lb bags of Sakrete tube sand, stacked ontop of each other at the tailgate held in place with a strap
Old Dec 26, 2010 | 08:24 PM
TX Chris's Avatar
I've got a pallet of roof shingles left over from having my house re-roofed. If it snows here (doubtful this year), I'll throw them in the rear of the bed. I don't know what each one weighs (guessing 40-50 pounds), but I've got 8 or 10 of them I can use.
Old Dec 26, 2010 | 08:44 PM
snopro31's Avatar
nothing if im going far.
but in town and within 1 hour i have my snowmobile in the back
Old Dec 26, 2010 | 09:33 PM
AirsoftF150's Avatar
200 lbs. 4 50 pound sand bag directly over the rear axle.
Old Dec 26, 2010 | 11:58 PM
marshal's Avatar
if you moved the sand further back to the edge of the bed you'd be better off. as of right now some of your weight is being supported by the front suspension (negatively[weight]), the further back it is in your bed the leverage changes to the rear, thus relieving (negative) leverage from the front suspension and applying it to our awful, awful goodyear GS/A's and Perelli Scorpions.
Old Dec 27, 2010 | 12:30 AM
Alex_4.2L's Avatar
two hundred pounds-4 fifty pound bags of sand
Old Dec 27, 2010 | 01:01 AM
mete's Avatar
Exclamation
about 200 lbs will work well.
There is an aftermarket device for that .A plastic pod that fits into the bed.You just add as much water as you want to get the weight.
www.shurtrax.com
Old Dec 27, 2010 | 01:14 AM
seadragon's Avatar
6 bags of gravel @ 66 lbs each for a total of 396 lbs.
Old Dec 27, 2010 | 06:49 PM
#16F150's Avatar
I think 200lbs is a good starting point, thanks for the inputs!
Old Dec 27, 2010 | 07:02 PM
CyberJeff's Avatar
I don't have any weight in the back of mine. I put on some Dunlop Rover MT's (maxx Traction) and those things have a bunch of traction. I have never been happier with a set of tires
Old Dec 27, 2010 | 07:11 PM
200 lbs as well
Old Dec 27, 2010 | 09:15 PM
nightingale's Avatar
Zero for me.
