Cold weather suspension noise
Old Dec 2, 2010 | 08:36 AM
5picker's Avatar
With the recent onset of cold, snowy weather here in western PA, I've noticed some suspension noise and wondered if anyone else has as well?
Running over the same railroad tracks and rough places with snow on the ground the temps at 20º sounds like I'm hauling a bunch of loose lumber under my truck.
Poor shocks maybe?
Old Dec 2, 2010 | 07:11 PM
cliff hanger's Avatar
I haven't had the suspension noises, but I sure can hear all of the plastic pieces creaking.
Old Feb 10, 2011 | 10:11 AM
Drumslinger's Avatar
Noise
I've got that same noise too since bad weather here in tx 5picker....let me know if you find out anything and I'll do the same.
Old Feb 10, 2011 | 10:40 AM
snopro31's Avatar
its normal.
6 months of below 0C weather here a year and every vehicle i have had or been in has the noise cause of the cold. only way to fix it is to move to mexico
Old Feb 10, 2011 | 02:21 PM
Mikedom's Avatar
If you have ice chunks in between the cab and the front of the box they will rattle around when going over bumps in the road. Mine did this on my 2004, and now seems worse with my 2010. The gap between the box and cab seems smaller on the 2010. This maybe your problem. Mike
Old Feb 10, 2011 | 05:25 PM
F 1Fiddy's Avatar
My windshield chirps and my door panels rattle. Very annoying.
Old Feb 10, 2011 | 07:14 PM
I've got that and it drives me nuts with the noise. Ice chunks get caught between the bed and the tonneau. The joys of winter.
Old Feb 10, 2011 | 07:31 PM
radar's FX4's Avatar
Originally Posted by snopro31
its normal.
Or south florida....about the same, better brush up on your espanol!
Old Feb 10, 2011 | 07:33 PM
Westpoint's Avatar
Same thing here! All these new noises are freakin me out. I just moved from warm southern California to cold Colorado. I never had a rattle at all before. And the roads here in the cold states are horrible.
Old Feb 10, 2011 | 07:57 PM
mete's Avatar
I don't usually worry about cold weather noises as long as they disappear as things warm up. The ice behind the cab thing through me until I read about it here. It's very loud and annoying too !! I found a strip of 1/4" thick plastic , cut it about 4" wide and cut course teeth .When fresh snow is cleaned off the truck I make sure it's all cleaned out from between cab and bed .No more noise !!
Old Feb 10, 2011 | 08:52 PM
snopro31's Avatar
i thought the whole southern half of the states was mexico now? lol
Old Feb 12, 2011 | 01:15 PM
juneau76's Avatar
I'm used to every vehicle rattling in the winter. I'm not a big fan of the snow melting and causing the huge icicles to hang from the front edge of the front doors. If you don't kick them off it sounds like you're grinding all the paint off your door.
Old Feb 12, 2011 | 09:19 PM
digbyz's Avatar
i get the ice rattling between the cab and bed and if i turn fast it squeeks from the dash. its been about 8 deg average in central il the past few days tho. my 2wd does verry good in the snow until we get a foot of snow then i'm S.O.L
