Door Check Replacement?
Old Nov 29, 2010 | 07:26 AM
tomseal6's Avatar
Last week while in Oklahoma the wind was blowing pretty hard all night around 50 MPH. The fire alarm went off at about 4AM so I had to go outside wait for the fire department to clear the building where Im staying It was so cold and miserable I decided to sit in my truck during that time. When I opened the door to go back to my room, the wind was blowing so hard that it yanked the door out of my hand and hyper extended the door
I called the ford dealer and I think I need to replace the black plastic hinge in the middle. Its called a door check, designed to give out first before your main hinges do. Its a $22 part. Wont be in until Tuesday and has to be shipped up from Ft Worth Texas
The door check makes a loud popping noise when I open the door and it is coming from that piece, since I have verified that it pops. No damage has been done to the main hinges or door.
Am I heading in the right direction with this and is the door check hard to replace?
Old Nov 29, 2010 | 05:20 PM
tomseal6's Avatar
nobody?
Old Nov 29, 2010 | 05:41 PM
KazK's Avatar
Make them fix it. You didn't break it. The different settings they have to where it stops are horrible.
Old Nov 29, 2010 | 05:43 PM
Stu486's Avatar
the wind? lol, he said the wind grabbed it and ripped it out of his hands.
wait a little for responses, sooner or later someone with an answer or good suggestion will let you know.
Old Nov 29, 2010 | 08:01 PM
redfx4150's Avatar
Wind damage like this can mess a door all up. Some pics would be helpful
It the door when closed looks like nothing happen the hinges and door frame are ok and you might just need the closure which is more then likey what is make the noise
Also to replace it youll need to take off the door panel I think I'll have to look at it tmr
Old Nov 29, 2010 | 08:24 PM
tomseal6's Avatar
main hinges and door frame is ok. The door seems to open very slighty more then it use to but the hinges are ok.
What is the closure? u lost me with that
EDIT: The lines and creases still match up and still look perfect from the factory
Old Nov 29, 2010 | 09:34 PM
xciton's Avatar
I'm surprised the plastic assembly held up protecting the hinges.
Old Nov 29, 2010 | 09:54 PM
tomseal6's Avatar
are you talking about the same plastic piece I am?
Old Nov 30, 2010 | 06:30 AM
redfx4150's Avatar
It's the black metal rod the goes from the door to cab between the hinges, it's what stop the door from opening to far and also holds it open
Old Nov 30, 2010 | 10:49 PM
tomseal6's Avatar
Im picking up a new one tomorrow. I doubt Ill be able to replace under warranty since it was more my fault and not fords
Old Dec 1, 2010 | 05:46 PM
tomseal6's Avatar
I went to dealer today to pick up my new door check. I had a body shop Tech come out and show how to replace it.
It turns out that the wind grabbed the door so hard that the very front of the door where the crease is actually made contact with the hing and dinged it in 2 places. It is so small that it is hardly noiceable unless your right up on it.. He also pointed out to me by comparing the drivers side crease to the passenger crease that it actually pulled the outer shell in very slightly just a few millimeters. He noticed it and I never did so he had to show it to me in order for me to see it.
Its in the center where the door check is located so I am hoping the new door check straightens is out. He told me if it doesnt, he knows a few tricks and offered to do it for free. I didn't even buy the truck there. What an awesome dealership!!
Old Dec 1, 2010 | 05:53 PM
tomseal6's Avatar
He also said the internals on the door check are shot.
Old Jun 30, 2011 | 09:34 PM
jlovette's Avatar
New door check not so good
I am certain the people that design these things don't drive them. The doors on my old 06 had two stopping points for opening the door in tight places. Now my 2-10 and thats wide open. Has one anyone had anyluck using a door check from a expediton or older F-150?
Old May 2, 2012 | 07:31 PM
DM06F150's Avatar
tomseal6
What did the body shop show you on how to replace the door check?
Old May 2, 2012 | 10:43 PM
aussiekeeper's Avatar
"They" didn't break it, nor was it a factory defect. You are a Democrat, huh?
