Fuel mileage question, seems strange.
Old Oct 7, 2010 | 08:47 PM
Relsek's Avatar
Originally Posted by trk35
Can't make horsepower unless you're burning fuel. Why worry about fuel mileage at 90mph? Go out and buy a Hybrid car if you want fuel mileage. You want to go somewhere with a truck, fill it with fuel and go. Don't be so darn cheap!!
Who's "worrying" about fuel mileage, I was just making an observation. Did you just climb out of a hole or something?
Old Oct 28, 2010 | 08:46 AM
ChipB727's Avatar
Happy Tailwinds!
Old Oct 28, 2010 | 09:21 AM
expy03's Avatar
Originally Posted by oijudd
I drive my 09 Platinum 100 miles a day (mostly) on the autobahn here in Germany. I'd venture that you were going down hill with a tail wind to get that high over 80. I've driven mine for my commute at all speeds and found:
60-65 @ 20.1
70-75 @ 19.4
80-85 @ 18.2
90+ @ 17.0
P.S. I run Royal Purple motor oil and a K&N Drop in Air Filter. It DOES make a difference
My numbers are pretty close. Although I have gotten as much as 22 mpg at 65. Stock oil and K&N. I just took a long trip of about 3000 miles and will finish it up today, so I will post the numbers tonight or tomorrow.
Old Oct 28, 2010 | 12:34 PM
ajsturtz's Avatar
We just had the nasty low pressure system roll through Iowa the past two days. Going to Des Moines, with a 30mph sustained tail wind, I got 22.3 mph driving at 70mph. Coming back, I got 12.6mpg on the same road (which is pretty darn flat). On level ground the truck kept downshifting to push the headwind.
Wind plays a HUGE part in mileage for these trucks. I haven't been able to noticeably alter fuel economy with filter or fluid changes in my 65k of highway driving.
BTW we just switched to winter blend fuels in Iowa, because my mileage dropped 1.5 almost overnight and is now locked in at about 16.5mpg per tank of highway driving.
IowaAndy
Old Oct 28, 2010 | 12:42 PM
Power Kid's Avatar
Originally Posted by rok
its more likely you got better mpg cause your engine broke in. I personally dont like RP. its to thin and made my car run worse than before.
RP "made my car run worse than before" ? Did you put it in the gas tank? WOW full syntetic oil made it run worse? What kind of car?
Old Oct 28, 2010 | 01:36 PM
tradosaurus's Avatar
IowaAndy
I got rid of my windshield wipers and the reduced drag gained me 3 mpg.
Old Oct 28, 2010 | 10:01 PM
Brute's Avatar
I go to UCSD so I have driven many times from L.A. to S.D. and back.
I have cruised at 74mph the entire way and have gotten 20mpg flat.
I have also cruised at 80mph the entire way and have gotten 22.5mpg flat.
I am thinking that temperature can make a big difference. I have gotten 19mpg before also at 74mph
Last week I cruised at 65mph the last 44 miles and got 25.5mpg
Old Oct 29, 2010 | 09:00 AM
I find that hard to believe on California goatpiss gas, Brute. If you are basing this on the lie-o-meter, are you confirming it with actual gallons/miles math? If it confirms, you are very lucky. What model is the truck, what engine, tranny, and axle ratio?
Old Oct 30, 2010 | 06:24 PM
johndeerejosh's Avatar
i drive 65 with cruise control and only get 16.1- 16.3 on a warm day what the hell is wrong with my truck is you guys are getting 19 at 80mph
2010 xlt screw
5.4l
Old Nov 1, 2010 | 04:52 AM
Brute's Avatar
MPG estimates from the truck's meter. I don't do calculator math anymore because I found it to be pretty accurate (I'm an econ major I know my math)
'09 3.31 axle, 4.6 3v xlt supercrew
Old Nov 1, 2010 | 07:19 AM
juneau76's Avatar
I know about winter blend diesel fuel, but I've never heard of winter blend gasoline and I live in one of those climates, too. What do they do to winterize it?
EDIT: Please strike my last comment from the record. Google helped me understand. Wow, I just never knew that.
