Is it realistic for someone to install a lowering kit without air tools?
Old Aug 31, 2010 | 03:32 PM
BIGG-RAY's Avatar
Hey guys. I want to install a 2/4 drop kit on my truck and the only tools I have are sockets, screwdrivers, ect - nothing powered by air. I know there is a bolt on the lower control arm that you have to remove to replace the spindle/shock assembly that requires something like 280 ft/lbs. That seems pretty high for just hand tools. Ideas?
Old Aug 31, 2010 | 03:34 PM
Ford12508's Avatar
280ft/lbs is nothing if you have quality tools. I am not a big person and can put down 120ft/lbs semi easily on a 16-18" torque wrench. Get out your 3/4" breaker bar, put a pipe on the end of it, and you now I have 5' bar, which is like 56ft/lbs on a 1 foot ratchet, which is pretty easy.
Old Aug 31, 2010 | 03:36 PM
johnwill's Avatar
The leverage is a great thing.
It can be your friend. The ancients used it wisely too.
Good luck.
Old Aug 31, 2010 | 04:38 PM
redfx4150's Avatar
a breaker bar and a 3 ft pipe and you will have no trouble, but it will take longer and might be harder on the back and knees
Old Sep 1, 2010 | 12:41 AM
BlueScrew150's Avatar
Torque spec is similar for the bolt on on the LCA on my truck. I put on a leveling kit without air tools. A good cheater bar is the way to go. You'll probably have to buy/"rent" a b'gass socket though.
Electric impact guns are fairly affordable and quite handy.
Old Sep 1, 2010 | 01:20 AM
stompy's Avatar
I installed a 2/4 drop on my old truck with no problem at all. No air tools....just hand tools and a helping hand. Go for it!
