How do you service these 6spd transmissions?
Old Aug 12, 2010 | 08:27 AM
f4ipilot's Avatar
Originally Posted by redfx4150
Fuel filter is now part of the fuel pump, so to change it you would have to replace the pump and I'm pretty sure the only way to change the trany filter is while rebuilding it or just to tear it apart, not like the old days any more
The way to change the tranny filter is easy, take the pan off, very much like the old days. The pan comes off very easily when you remove the bolts that are holding it on. Once you take the pan off the filter is the first thing you will see and it pulls out very easily.
Then the dipstick is on the side of the transmission.
Old Aug 12, 2010 | 07:21 PM
D8Chumley's Avatar
Originally Posted by stormtech
I guess my manual is different than yours -
First mention of a transmission fluid change in my manual is 150,000 miles.
You are correct, I misread the service guide. It only says to inspect auto trans fluid level on vehicles equipped with a dipstick. What has a dipstick anymore, maybe just the SD? I don't think I'm going 150K on a trans fluid change either. Sorry for the mis-information, I thought I read 30K in the manual.
Old Aug 12, 2010 | 09:26 PM
They have a dipstick - you have to get under the truck to get at it. It's attached to the plug.
Old Aug 13, 2010 | 09:46 PM
d4studmuf1n's Avatar
yes the dipstick is on the side of the tranny but to check the level correctly you must have a scan tool connected to the car and monitor the temperatures, which according to the service manual the temp should be 175°F-185°F i can put the whole procedure up if you really want it...
Old Aug 15, 2010 | 10:42 AM
Formula jg's Avatar
Where exactly is the dip stick?
Is it accessable from under the hood or do I need to get under the truck?
Old Aug 15, 2010 | 10:48 AM
shotgunz's Avatar
Old Aug 16, 2010 | 09:37 AM
DjG's Avatar
DjG
Here is a link to a thread done awhile back about the trans. dip stick it has photo's and shows how to remove the dip stick.
https://www.f150online.com/forums/20...dip-stick.html
Old Aug 17, 2010 | 08:45 AM
Formula jg's Avatar
DjG,
Thank's man, thats a good thread.
Old Aug 17, 2010 | 11:06 AM
DjG's Avatar
DjG
DjG,
Anytime thats what we are here for to help each other out.
