Code Alarm Shock Sensor Reprogram
Old Jul 26, 2010 | 11:02 PM
whiskerbiscuit's Avatar
Question Code Alarm Shock Sensor Reprogram
Does anyone know if there is some magical key sequence that will allow me to change the shock sensor sensitivity? I have spent the last two hours searching google and different alarm sites, but could not come up with anything. I thought there has to be some easy way to do it. Maybe there isn't. I have the CA-6550, which has been sweet and has worked great. The problem comes when I drive by with my motorcycle. Also, it is always chirping when a car door is closed next to it. And to top it off, the other day it was raining hard (no thunder), and the darn thing kept chipping.
Any help or a point in the right direction would be greatly appreciated.
Old Jul 26, 2010 | 11:21 PM
SteveVFX4's Avatar
Doesn't it tell you how to adjust it in your owner's manual?
try this website for Code Alarm install or owner's manuals, you have to sign up for a username and password first:
http://techservices.codesystems.com/Login.aspx
Old Jul 26, 2010 | 11:35 PM
SteveVFX4's Avatar
ok, here's the ca6550 install manual from that site, hope this direct link works:
http://documents.codesystems.com/710820.pdf
you have to find your shock sensor. on page 22 it says this:
Adjusting the Shock Sensor
1. Increase sensitivity by turning the adjustment dial clockwise.
2. Decrease sensitivity by turning the adjustment dial counter clockwise.
Old Jul 27, 2010 | 08:27 PM
I didn't install this myself, so I never got an install manual. Your download link worked perfectly. Thanks.
Now I just have to find the darned thing. Probably be quicker to just go to the dealer and have them adjust it.
Thanks again.
Old Jul 27, 2010 | 08:52 PM
SteveVFX4's Avatar
sure no problem.
I have the 6-button Ford alarm/rmst and the shock sensor is built right into the brain unit. and the actual owner's manual tells you how to adjust the sensitivity of it.
